bltouch sensor
Posted by bastard
bltouch sensor
July 04, 2017 07:43AM
I would like to use a bltouch sensor in my Mendel90 kit printer.
So I drawn it in OpenSCAD:
Then I tried to attach it at the x-carriage:
The naked x-carriage looks like this:
There are two screws + nuts needed. To be able to adjust the height I think a few washers between the mounting plate and the x-carriage should be enough. So far so good. As you can see, there is no room for the nuts, so I trapped them under the motor. Do you think that would work at all?
Then the Melzi needs a new firmware. Is Neil's version able to handle such a sensor? Is anybody else interested in the files I changed?
MfG / Regards
Stefan
Blog / Gallery / Wiki / Mendel90 kit since Sep 2013 from Nophead / Original Prusa I3 MK3 since Feb 2018 /
OpenScad Workshop: Kursdateien
Octoprint Patron since April 2016
Re: bltouch sensor
July 05, 2017 07:37AM
I tend to use heatfit threaded brass inserts instead of trapped nuts these days.
I would try to move it nearer the hot end so it probes as close as possible. You can replace one of the wingnuts with one of these: [hydraraptor.blogspot.co.uk] to make room. I would probably just press fit an insert to make those nowadays rather than a captive nut.
I haven't investigated Marlin's bed levelling or kept up with its development.
Edited 1 time(s). Last edit at 07/05/2017 07:38AM by nophead.
