At start of print only one z axis is working September 06, 2017 03:52PM |
Re: At start of print only one z axis is working September 07, 2017 04:13AM |
Admin Registered: 18 years ago Posts: 7,883 |
Re: At start of print only one z axis is working September 07, 2017 04:11PM |
printrun
Setting bed temperature to 60.000000 degrees Celsius.
Can't write to printer (disconnected?).
Can't read from printer (disconnected?).
Can't even kill the process. I have to turn off the printer and then the application closes.
) and hope it will work afterwards.|
Re: At start of print only one z axis is working September 29, 2017 11:02PM |
Re: At start of print only one z axis is working October 01, 2017 03:31PM |
http://reprap.org/wiki/Melzi
Melted screw terminals
Sometimes, the screw terminals on a Melzi melt. More often than not, it's the bed terminal, and is due to the wire being poorly connected, ie loose in the screw terminal. It can also cause the MOSFET to fail, as it cannot dissipate heat generated as it switches on and off. RepRapPro advises customers to check the screw terminal connections periodically: [reprappro.com]
If the Melzi PCB is undamaged, you can simply replace the screw terminal. There are a couple of different screw terminal blocks, these are the most common:
This is the most common one - [uk.farnell.com]
this one is a bit taller, and easier to get the wires into - [uk.farnell.com]
The heated bed power cable carries about 10A at 12V, so any poor connection will tend to heat up. Check that your power and heated bed wires are stripped back far enough to go well into the screw terminals, and it's always worth checking that the screw terminals are well-tightened occasionally. Also, wire the printer with enough slack on the heated bed power wire so that it can be attached to frame, and there shouldn't be any movement of it at the Melzi end. But strain relief on any moving wire is necessary - try to make the movement in the actual wire, rather than at a connection point, to avoid the wire fatiguing.
Re: At start of print only one z axis is working October 04, 2017 03:52PM |
