Mendel90 setup July 16, 2018 09:32AM |
Re: Mendel90 setup July 16, 2018 09:47AM |
Re: Mendel90 setup July 16, 2018 10:17AM |
Re: Mendel90 setup July 17, 2018 09:07AM |
Re: Mendel90 setup July 17, 2018 09:48AM |
#define INVERT_X_DIR false #define INVERT_Y_DIR true #define INVERT_Z_DIR false
Re: Mendel90 setup July 17, 2018 12:10PM |
Admin Registered: 14 years ago Posts: 7,855 |
Re: Mendel90 setup July 18, 2018 03:12AM |
Re: Mendel90 setup July 18, 2018 09:50AM |
Re: Mendel90 setup July 22, 2018 06:18AM |
Re: Mendel90 setup July 22, 2018 10:45AM |
Re: Mendel90 setup July 22, 2018 02:45PM |
Re: Mendel90 setup July 22, 2018 05:56PM |
Re: Mendel90 setup July 23, 2018 05:14AM |
Re: Mendel90 setup July 23, 2018 07:05AM |
Re: Mendel90 setup July 26, 2018 05:50AM |
Re: Mendel90 setup July 26, 2018 06:13AM |
Re: Mendel90 setup July 26, 2018 06:27AM |
nophead
They should change to H if they are pressed while M119 is typed. The switch should open and the input pulled high.
>I didn't make any changes to the firmware, loaded it straight up from the USB.
Not sure what you mean by that. It should have had firmware already installed and be ready to use. Did you load new firmware via USB using the Arduino IDE? If so where did you get it from?
Re: Mendel90 setup July 26, 2018 06:30AM |
Re: Mendel90 setup July 26, 2018 06:37AM |
Re: Mendel90 setup July 26, 2018 07:02AM |
Re: Mendel90 setup July 26, 2018 07:13AM |
Re: Mendel90 setup July 26, 2018 07:44AM |
Re: Mendel90 setup July 26, 2018 07:54AM |
