I would suggest that you download the Mendel90 manual, available here [
github.com] , and go through it making sure that all of the printed parts are in good order, the fixing screws are tight and that the electrical connecrtions are all making good connections. If anything is not in good condition then replace it. You will need to level the bed, set the Z-axis home height and e-steps in the software, instructions are in the Manual, and then try a test print.
Best of luck
Richard
