Corners not sharp after switching to 2GT belts March 11, 2021 08:28AM |
Re: Corners not sharp after switching to 2GT belts March 12, 2021 12:19AM |
Admin Registered: 13 years ago Posts: 7,000 |
Re: Corners not sharp after switching to 2GT belts March 12, 2021 03:35AM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Corners not sharp after switching to 2GT belts March 12, 2021 12:36PM |
Dust
DId you also get new *2GT* Pulleys, as from what I read 2GT tooth profiles are not the same as cheap gt2 pullies
nophead
Not sure what you mean by 20 tooth being lower resolution. 20 times 2 is 40mm, the same as 16 times 2.5 is 40mm. You shouldn't need to change any settings.
Your left hand cube has three outlines but the right only has two. If the inner outlines are done first I could imagine it would lead to more rounded corners. Other things that can affect it are the nozzle diameter, the plastic's viscosity, and the layer height.
If the belt profile does not match the pulleys I think the worst you would get is perhaps some backlash. I don't think you would get nicely rounded corners.
Re: Corners not sharp after switching to 2GT belts March 12, 2021 04:15PM |
Re: Corners not sharp after switching to 2GT belts March 24, 2021 05:48PM |
