Keep your counter clean with this dish wand & sponge organizer. It will hold both round or rectangle sponges depending on which anti-slide pin you use. Excess water is drained back into the sink and not left on the counter. Easy to print, no supports required. If you have a round sponge use the taller anti slide pin. Otherwise use two small ones. I hope this makes your kitchen just a little better
link: [
www.printables.com]-
Edited 1 time(s). Last edit at 11/26/2023 11:41AM by LostinNashville.
