Is this the kit you are looking at?
Github Kit from Prusa
If so there are two file types in there
1 - STL is the printable version of the files, Openscad is not needed for these.
2 - SCAD files can be open in Openscad and modified if needed.
You can just down load the whole folder to your computer. If you need them on a cd then you should be able to select that folder and drag and drop them (in finder) on to the CD/DVD drive (provided you have one, not all macs have it)
Easy way is to click on
this link and then click on download zip file. Once downloaded open that new folder and then go to the proper folder (i.e.: Mandel/Prusa) then use the files in that folder to either print the STL files and or copy them to a cd.
Rick
