Searching a STL for RAMPS module on I3 acrylic October 18, 2015 03:49AM |
Re: Searching a STL for RAMPS module on I3 acrylic October 27, 2015 10:20AM |
Re: Searching a STL for RAMPS module on I3 acrylic October 27, 2015 11:49AM |
//change the next 6 lines to match your dimensions
dim=20; //the width/height of the extrusion
wall=4; //how thick you want the walls to be
height = 50; //the length of the "sleeve"
hookwall = 6; //how thick is the wall aroung the "hook" portion
hookdepth = 6; //how wide is the aluminum over which the hook is hung
hookheight = 12; //how long is the portion of the hook that overhangs the aluminum
//don't change below this point
dim2 = (dim/2+wall)*sin(45);
rotate([0, 90, 0])
difference() {
union() {
rotate([-45, 0, 0])
translate([0, 0, height/2])
cube([dim+wall*2, dim+wall*2, height], true);
cube([dim+wall*2, dim2*2, dim2*4], true);
translate([0, -dim2-(hookdepth+hookwall)/2, dim2])
cube([dim+wall*2, hookdepth+hookwall, hookwall], true);
translate([0, -dim2-hookwall/2-hookdepth, dim2+hookwall/2-hookdepth/2-hookheight/2])
cube([dim+wall*2, hookwall, hookdepth+hookheight], true);
rotate([-45, 0, 0])
translate([0, 0, height/2+wall])
cube([dim, dim, height], true);
Re: Searching a STL for RAMPS module on I3 acrylic November 15, 2015 12:10AM |
