Hotend Direkt Isınıyor May 24, 2020 05:05AM |
Re: Hotend Direk Isınıyor May 24, 2020 04:42PM |
Admin Registered: 9 years ago Posts: 215 |
Re: Hotend Direk Isınıyor May 25, 2020 05:14AM |
elmek6
Merhaba,
Herkese önerdigimi sizede önerecegim. Zaten kisa bir forum tarihimiz var bastan asagi okuyun, orada güzel bir cözüm önerisi var.
Donanimsal bir ariza olabilir. Mosfeti kontrol edin. Kisa devrenin kaynagini bulamazsaniz yeni kart almaniz gerekebilir yine de bir firmware bulup yükleyebilirsiniz. E0 cikisini baska bir mosfete yönlendirebilirsiniz.
/** * Marlin 3D Printer Firmware * Copyright (C) 2016 MarlinFirmware [https://github.com/MarlinFirmware/Marlin] * * Based on Sprinter and grbl. * Copyright (C) 2011 Camiel Gubbels / Erik van der Zalm * * This program is free software: you can redistribute it and/or modify * it under the terms of the GNU General Public License as published by * the Free Software Foundation, either version 3 of the License, or * (at your option) any later version. * * This program is distributed in the hope that it will be useful, * but WITHOUT ANY WARRANTY; without even the implied warranty of * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the * GNU General Public License for more details. * * You should have received a copy of the GNU General Public License * along with this program. If not, see [www.gnu.org]. * */ /** * Arduino Mega with RAMPS v1.4 (or v1.3) pin assignments * * Applies to the following boards: * * RAMPS_14_EFB (Extruder, Fan, Bed) * RAMPS_14_EEB (Extruder, Extruder, Bed) * RAMPS_14_EFF (Extruder, Fan, Fan) * RAMPS_14_EEF (Extruder, Extruder, Fan) * RAMPS_14_SF (Spindle, Controller Fan) * * RAMPS_13_EFB (Extruder, Fan, Bed) * RAMPS_13_EEB (Extruder, Extruder, Bed) * RAMPS_13_EFF (Extruder, Fan, Fan) * RAMPS_13_EEF (Extruder, Extruder, Fan) * RAMPS_13_SF (Spindle, Controller Fan) * * Other pins_MYBOARD.h files may override these defaults * * Differences between * RAMPS_13 | RAMPS_14 * 7 | 11 */ #if !defined(__AVR_ATmega1280__) && !defined(__AVR_ATmega2560__) #error Oops! Make sure you have 'Arduino Mega' selected from the 'Tools -> Boards' menu. #endif #define LARGE_FLASH true #ifdef IS_RAMPS_13 #define SERVO0_PIN 7 // RAMPS_13 // Will conflict with BTN_EN2 on LCD_I2C_VIKI #else #define SERVO0_PIN 11 #endif #define SERVO1_PIN 6 #define SERVO2_PIN 5 #define SERVO3_PIN 4 #define X_STEP_PIN 54 #define X_DIR_PIN 55 #define X_ENABLE_PIN 38 #define X_MIN_PIN 3 #ifndef X_MAX_PIN #define X_MAX_PIN 2 #endif #define Y_STEP_PIN 60 #define Y_DIR_PIN 61 #define Y_ENABLE_PIN 56 #define Y_MIN_PIN 14 #define Y_MAX_PIN 15 #define Z_STEP_PIN 46 #define Z_DIR_PIN 48 #define Z_ENABLE_PIN 62 #define Z_MIN_PIN 18 #define Z_MAX_PIN 19 #define E0_STEP_PIN 26 #define E0_DIR_PIN 28 #define E0_ENABLE_PIN 24 #define E1_STEP_PIN 36 #define E1_DIR_PIN 34 #define E1_ENABLE_PIN 30 #define SDPOWER -1 #define SDSS 53 #define LED_PIN 13 // Use the RAMPS 1.4 Analog input 5 on the AUX2 connector #define FILWIDTH_PIN 5 // ANALOG NUMBERING #if ENABLED(Z_MIN_PROBE_ENDSTOP) // Define a pin to use as the signal pin on Arduino for the Z_PROBE endstop. #define Z_MIN_PROBE_PIN 32 #endif #if ENABLED(FILAMENT_RUNOUT_SENSOR) // define digital pin 4 for the filament runout sensor. Use the RAMPS 1.4 digital input 4 on the servos connector #define FILRUNOUT_PIN 4 #endif #if MB(RAMPS_14_EFF) || MB(RAMPS_13_EFF) || ENABLED(IS_RAMPS_EF #define FAN_PIN 9 // (Sprinter config) #if MB(RAMPS_14_EFF) || MB(RAMPS_13_EFF) #define CONTROLLERFAN_PIN -1 // Pin used for the fan to cool controller #endif #elif MB(RAMPS_14_EEF) || MB(RAMPS_14_SF) || MB(RAMPS_13_EEF) || MB(RAMPS_13_SF) #define FAN_PIN 8 #else #define FAN_PIN 4 // IO pin. Buffer needed #endif #define PS_ON_PIN 12 #if ENABLED(REPRAP_DISCOUNT_SMART_CONTROLLER) || ENABLED(G3D_PANEL) #define KILL_PIN 41 #endif #if MB(RAMPS_14_EFF) || MB(RAMPS_13_EFF) #define HEATER_0_PIN 8 #else #define HEATER_0_PIN 10 // EXTRUDER 1 #endif #if MB(RAMPS_14_SF) || MB(RAMPS_13_SF) || ENABLED(IS_RAMPS_EF #define HEATER_1_PIN -1 #else #define HEATER_1_PIN 9 // EXTRUDER 2 (FAN On Sprinter) #endif #define HEATER_2_PIN -1 #define TEMP_0_PIN 13 // ANALOG NUMBERING #define TEMP_1_PIN 15 // ANALOG NUMBERING #define TEMP_2_PIN -1 // ANALOG NUMBERING #if MB(RAMPS_14_EFF) || MB(RAMPS_14_EEF) || MB(RAMPS_14_SF) || MB(RAMPS_13_EFF) || MB(RAMPS_13_EEF) || MB(RAMPS_13_SF) #define HEATER_BED_PIN -1 // NO BED #else #define HEATER_BED_PIN 8 // BED #endif #define TEMP_BED_PIN 14 // ANALOG NUMBERING #if ENABLED(Z_PROBE_SLED) #define SLED_PIN -1 #endif #if ENABLED(ULTRA_LCD) #if ENABLED(NEWPANEL) #if ENABLED(PANEL_ONE) #define LCD_PINS_RS 40 #define LCD_PINS_ENABLE 42 #define LCD_PINS_D4 65 #define LCD_PINS_D5 66 #define LCD_PINS_D6 44 #define LCD_PINS_D7 64 #else #define LCD_PINS_RS 16 #define LCD_PINS_ENABLE 17 #define LCD_PINS_D4 23 #define LCD_PINS_D5 25 #define LCD_PINS_D6 27 #define LCD_PINS_D7 29 #endif #if ENABLED(REPRAP_DISCOUNT_SMART_CONTROLLER) #define BEEPER_PIN 37 #define BTN_EN1 31 #define BTN_EN2 33 #define BTN_ENC 35 #define SD_DETECT_PIN 49 #elif ENABLED(LCD_I2C_PANELOLU2) #define BTN_EN1 47 // reverse if the encoder turns the wrong way. #define BTN_EN2 43 #define BTN_ENC 32 #define LCD_SDSS 53 #define SD_DETECT_PIN -1 #define KILL_PIN 41 #elif ENABLED(LCD_I2C_VIKI) #define BTN_EN1 22 // reverse if the encoder turns the wrong way. #define BTN_EN2 7 // [files.panucatt.com] // tells about 40/42. // 22/7 are unused on RAMPS_14. 22 is unused and 7 the SERVO0_PIN on RAMPS_13. #define BTN_ENC -1 #define LCD_SDSS 53 #define SD_DETECT_PIN 49 #elif ENABLED(ELB_FULL_GRAPHIC_CONTROLLER) #define BTN_EN1 35 // reverse if the encoder turns the wrong way. #define BTN_EN2 37 #define BTN_ENC 31 #define SD_DETECT_PIN 49 #define LCD_SDSS 53 #define KILL_PIN 41 #define BEEPER_PIN 23 #define DOGLCD_CS 29 #define DOGLCD_A0 27 #define LCD_PIN_BL 33 #elif ENABLED(MINIPANEL) #define BEEPER_PIN 42 // Pins for DOGM SPI LCD Support #define DOGLCD_A0 44 #define DOGLCD_CS 66 #define LCD_PIN_BL 65 // backlight LED on A11/D65 #define SDSS 53 #define KILL_PIN 64 // GLCD features //#define LCD_CONTRAST 190 // Uncomment screen orientation //#define LCD_SCREEN_ROT_90 //#define LCD_SCREEN_ROT_180 //#define LCD_SCREEN_ROT_270 //The encoder and click button #define BTN_EN1 40 #define BTN_EN2 63 #define BTN_ENC 59 //the click switch //not connected to a pin #define SD_DETECT_PIN 49 #else #define BEEPER_PIN 33 // Beeper on AUX-4 // buttons are directly attached using AUX-2 #if ENABLED(REPRAPWORLD_KEYPAD) #define BTN_EN1 64 // encoder #define BTN_EN2 59 // encoder #define BTN_ENC 63 // enter button #define SHIFT_OUT 40 // shift register #define SHIFT_CLK 44 // shift register #define SHIFT_LD 42 // shift register #elif ENABLED(PANEL_ONE) #define BTN_EN1 59 // AUX2 PIN 3 #define BTN_EN2 63 // AUX2 PIN 4 #define BTN_ENC 49 // AUX3 PIN 7 #else #define BTN_EN1 37 #define BTN_EN2 35 #define BTN_ENC 31 // the click #endif #if ENABLED(G3D_PANEL) #define SD_DETECT_PIN 49 #else // #define SD_DETECT_PIN -1 // Ramps doesn't use this #endif #endif #else // !NEWPANEL (Old-style panel with shift register) #define BEEPER_PIN 33 // No Beeper added // Buttons are attached to a shift register // Not wired yet //#define SHIFT_CLK 38 //#define SHIFT_LD 42 //#define SHIFT_OUT 40 //#define SHIFT_EN 17 #define LCD_PINS_RS 16 #define LCD_PINS_ENABLE 17 #define LCD_PINS_D4 23 #define LCD_PINS_D5 25 #define LCD_PINS_D6 27 #define LCD_PINS_D7 29 #endif // !NEWPANEL #endif // ULTRA_LCD // SPI for Max6675 or Max31855 Thermocouple #if DISABLED(SDSUPPORT) #define MAX6675_SS 66 // Do not use pin 53 if there is even the remote possibility of using Display/SD card #else #define MAX6675_SS 66 // Do not use pin 49 as this is tied to the switch inside the SD card socket to detect if there is an SD card present #endif #if DISABLED(SDSUPPORT) // these pins are defined in the SD library if building with SD support #define SCK_PIN 52 #define MISO_PIN 50 #define MOSI_PIN 51 #endif #ifndef KILL_PIN // #define KILL_PIN -1 #endif
Re: Hotend Direk Isınıyor May 26, 2020 02:50PM |
