I messed-up a print of a Thingiverse bulletpuzzle object.
So I needed to only reprint a part (left bullet).
I can not post the .stl due to its size, but you'll find it here:
STL file
I imported the .stl and subtracted a cube, that was covering the right 5 bullets, presuming that only the left bullet would remain.
(See OpenScad file)
This happens: at F5, it draws as I expect, only the left bullet is drawn.
However at F6 (Render) only the cube remains.
Anybody any clue hat is causing this ? what do I wrong ?
Thomas
Edited 1 time(s). Last edit at 02/15/2014 05:31PM by Replace.
www.3daybreaker.blogspot.com
Orca V4.4 rebuild to Ramps with Mk8 and E3D, as well as a Rostock Delta Mini and an OLO in backorder :-)
