Impossible shape ?
Posted by Replace
Impossible shape ?
October 16, 2014 10:08AM
Currently, I am designing an OpenScad copy of my MarkV Diving helmet.
You can see the results up till now here : MarkV Helmet
As you can see, most of the shapes come out very well, not the least by using the hull function :-), but I have no idea how to start shaping the collar-sleeve (The bent-in-two-directions shoulder part.)
The cylinder part is not the problem. The rest of it is.
Any idea's what function I could use ? I am thinking of subtracting cylinders or torusses from something, but for now, no inspiration yet.
Any thoughts by specialists ?
(Yes I know it can maybe done simple in other tools, but I only now OpenScad a bit :-)
Thomas
Edited 1 time(s). Last edit at 10/16/2014 10:09AM by Replace.
www.3daybreaker.blogspot.com
Orca V4.4 rebuild to Ramps with Mk8 and E3D, as well as a Rostock Delta Mini and an OLO in backorder :-)
Re: Impossible shape ?
October 16, 2014 06:26PM
Try this for a START:
$fn=100;
intersection()
	scale([1,0.75,1])
		cylinder(r=24, h=100, center=true);
	translate([0,0,50])
		cube([100,100,90], true);
	difference()
		union()
			translate([0,0,20])
				cylinder(r=12, h=20, center=true);
			translate([0,0,0])
				rotate([0,90,0])
					cylinder(r=20, h=40, center=true);
		translate([0,0,21])
			cylinder(r=10, h=22, center=true);
		translate([0,0,0])
			rotate([0,90,0])
				cylinder(r=18, h=41, center=true);
Bob Morrison
Wörth am Rhein, Germany
"Luke, use the source!"
BLOG - PHOTOS - Thingiverse
October 17, 2014 07:34AM
Ahhh... the INTERSECTION command,
I had never played with that one before. Just learning OpenScad on the spot.
Thanks for the heads-up. This is great.
(How about my other attempts to imitate the MarkV parts? )
BTW, I love your way to make an oval out of a scaled cylinder.
I was used to hull 2 cylinders, but this renders probably faster :-)
Thomas
Edited 1 time(s). Last edit at 10/17/2014 07:37AM by Replace.
October 17, 2014 09:13AM
The hull() and minkowski() functions should only be used when absolutely necessary.
They are great and when you need it - USE IT, but if it can be done simpler, then DO SO!
Replace
Looks good!
Bob Morrison
October 17, 2014 12:18PM
Replace
A hull of two cylinders will not create an oval - it will have two straight sides (between the cylinders) rather than the entire perimeter being curved, and additionally the curved ends will have a constant radius rather than a continually changing curvature.
Dave
October 17, 2014 01:24PM
you can scale a cylinder by different multiples on different axes to get an oval.
whoops - I just read through the previous posts - my post was a bit redundant!!
Edited 2 time(s). Last edit at 10/17/2014 01:25PM by jbernardis.
October 17, 2014 02:39PM
Hi Rob,
thanks for the heads-up.
This is my result:
Thomas
October 18, 2014 05:04AM
Looks pretty nice. Good job!
Bob Morrison
October 18, 2014 08:11AM
I gave you the credit for this part on Thingiverse :-)
October 18, 2014 06:15PM
smileys with beer
Bob Morrison
October 22, 2014 08:38AM
Replace
...EXCEPT - You spelled my name wrong, there is only one (1) 's' in "rhmorrison". sad smiley
Bob Morrison
October 22, 2014 05:39PM
I stand corrected
I apologise
I have made a correction immediately
I am sorry
I hope we can still be friends
Thomas
p.s. maybe it was a language thing :-)
