"write.scad" not found? May 26, 2015 12:10PM |
use ..... Font = "write/Letters.dxf";//["write/Letters.dxf":Basic,"write/orbitron.dxf":Futuristic,"write/BlackRose.dxf":Fancy]
Re: "write.scad" not found? May 26, 2015 06:57PM |
Admin Registered: 13 years ago Posts: 1,063 |
Re: "write.scad" not found? May 27, 2015 04:36AM |
thejollygrimreaper
did it work with a previous version?
DEPRECATED: The assign() module will be removed in future releases. Use a regular assignment instead.Probably that happend to the write.scad module too?
Re: "write.scad" not found? May 27, 2015 04:51AM |
o_lampe
thejollygrimreaper
I don´t know.
I just started with openSCAD, was used to use SolidWorks before.
I also get another warning
This geared cube is one of the most popular things on thingiverse, it was published ~2012
Which version should I use? Or can I reassign a different font? How?
-Olaf
Re: "write.scad" not found? May 27, 2015 08:16AM |
Re: "write.scad" not found? May 28, 2015 08:47AM |
