Can't figure this out - need some advice
Posted by andy.wpg
June 29, 2015 05:15PM
I'm making an end cap that goes in the end of a carbon fiber tube with an outside diameter of 12mm and an inside diameter of 10mm.
To that end, I created the following:
difference ()
		union ()
				cylinder(13,3,3,$fn=100);  //main cylinder
				cylinder(3,6,6,$fn=100);   //disk on end
				translate([0,0,5])
				cylinder(1,5,5,$fn=100);   //fin 1
				translate([0,0,7])
				cylinder(1,5,5,$fn=100);	//fin 2
				translate([0,0,9])
				cylinder(1,5,5,$fn=100); //fin 3
				translate([0,0,11])
				cylinder(1,5,5,$fn=100);  //fin4
		translate ([0,0,1])
		cylinder(25,1,1,$fn=100); //hollow center
This works just fine, and looks......ok. What I really want to do is make the end cap (the 12mm X 3mm disk) into a slightly domed shape so it will look nicer. That's been the problem. Nothing I've tried works. Anyone have any advice?
Thanks,
Andy
"I have noticed that even those who assert that everything is predestined and that
we can change nothing about it still look both ways before they cross the street"
-Stephen Hawking
Re: Can't figure this out - need some advice
June 30, 2015 02:24AM
How about that?
difference ()
		union ()
		translate([0,0,3])
                cylinder(10,3,3,$fn=100);  //main cylinder
		intersection(){
                    translate ([0,0,6])
                    sphere(6, $fn=100);
				translate([0,0,5])
				translate([0,0,7])
				translate([0,0,9])
				translate([0,0,11])
		translate ([0,0,1])
You can play around with the sphere size and it´s translation value until you find a nice looking shape. ( I like "12" for both )
Edited 2 time(s). Last edit at 06/30/2015 02:31AM by o_lampe.
June 30, 2015 10:02AM
o_lampe
How about that?
Perfect! You have no idea how much I messed around trying to achieve that! I should mention, while I have many technical talents, math and I don't get along very well, so sometimes, SCAD is a challenge for me.
Thanks again
-Stephen Hawking
August 16, 2015 01:37AM
Sorry about replying to an old topic. I am still learning Openscad but I have been a hobby programmer for many years. I slightly modify o_lampe's code to use a for loop
difference ()
		union ()
		translate([0,0,3])
		intersection(){
                    translate ([0,0,6])
                    sphere(6, $fn=100);
                //For loop Z = 5 to 11 step 2 - Z movement
                for (z = [5:2:11]) {
                    translate([0,0,z])
                    cylinder(1,5,5,$fn=100);   //4 fins
		translate ([0,0,1])
Edited 1 time(s). Last edit at 08/16/2015 01:39AM by rrowan327.
October 02, 2015 04:16AM
Or
for (z = [5,7,9,11])
