Use stl, dxf file to mod part August 17, 2015 01:14PM |
$fa = 0.5;
$fs = 1.5;
b_width = 124.7;
b_depth = 28.5;
b_height = 24;
b_circle = 30.5;
b_circle_length = 17;
slot_width = 10.5;
slot_height = b_height +1.2;
slot_angle = 0;
base();
module base() {
difference() {
cube([b_width, b_depth, b_height]);
//circle cuts
//left
translate([b_width/2+40,b_height-10,slot_height+5]) circlecutout2(1.2);
//center
translate([b_width/2,b_height+7,slot_height]) circlecutout();
//right
translate([b_width/2-40,b_height-10,slot_height+5]) circlecutout2(1.2);
//slot cut
translate([-3,b_height-13,6]) slotcutout();
//Front cut
translate([-1.5,b_depth/2,b_height/1.2]) fCut();
module circlecutout() {
rotate([90,0,00])
cylinder(h=b_circle_length, d=b_circle);
module circlecutout2(scx) {
rotate([-70,0,0])
cylinder(h=b_circle_length, d=b_circle*scx);
module fCut() {
cube([b_width+3, b_depth/1.5, b_height/2]);
module slotcutout() {
rotate([15,0,0])
minkowski() {
cube([b_width + 8, slot_width-1, slot_height+5]);
rotate([0,90,0]) cylinder(r=2,h=slot_height+5);
Re: Use stl, dxf file to mod part August 17, 2015 03:39PM |
module slotcutout(opening=10) {
rotate([15,0,0]){
hull() {
translate([0,-opening/2-2,slot_height+5])cube([b_width+8,slot_width+3+opening,1]);
rotate([0,90,0]) cylinder(r=2,h=b_width+8);
translate([0,slot_width-1,0])rotate([0,90,0]) cylinder(r=2,h=b_width+8);
Re: Use stl, dxf file to mod part August 17, 2015 10:07PM |
Re: Use stl, dxf file to mod part August 17, 2015 11:03PM |
Re: Use stl, dxf file to mod part August 18, 2015 12:19AM |
Re: Use stl, dxf file to mod part August 18, 2015 10:20PM |
Re: Use stl, dxf file to mod part August 19, 2015 01:07AM |
rrowan327
P.S. how do I go from either openscad or STL file to png/jpeg? I couldn't figure out how to display the file in this forum. I have an imgur account but they what a raster file.
Re: Use stl, dxf file to mod part August 19, 2015 05:11AM |
Re: Use stl, dxf file to mod part August 19, 2015 10:30AM |
rhmorrison
To post the image:
1. Click on "Attach a file ..."
2. Click on "Browse..." button
3. Select the image file and click on "Open"
4. Click the "Attach" button
5. Click on "Create link in message"
[attachment 60257 DoubleFacepalm.jpg]
Re: Use stl, dxf file to mod part August 19, 2015 10:47AM |
enif
In OpenScad I use "File / Export / Export as image" to generate a PNG from a Scad-File
Re: Use stl, dxf file to mod part August 19, 2015 12:01PM |
