poor maths again
October 11, 2015 12:22PM
I'm trying to construct a small scad to produce 20 holes in a platform of increasing size of 0.05 whilst maintaining the same distance between adjacent hole edges.
this is what I have tried
difference(){
cube ([100,8,3]);
for (x= [1:5:100]){
for (y=[3.0:0.05:4.9]){
translate([x,3+y,-0.1]) cylinder(h=4,r=y+0.05);
It will be obvious that for each value of x it produced all values of y, I only want 1 value of y for each value of x but y increased by 0.05.
My maths is so poor that I can't see how to do this.
Thanks for any help
appjaws - Core XYUV Duet Ethernet Duex5
firmware 3.1.1 Web Interface 3.1.1
Ormerod 1-converted to laser engraver, Duet wifi
OpenSCAD version 2020.07
slic3r-1.3.0, Simplify3D 4.1.2, Cura-4.4.1
Re: poor maths again
October 11, 2015 01:52PM
difference(){
  cube([100,8,3]);
  for(i=[0:19]){
    translate([1 + 5*i, 6+0.05*i, -0.1]) cylinder(h=4,r=3.05 + 5*i);
Edited 2 time(s). Last edit at 10/11/2015 01:53PM by dc42.
October 11, 2015 02:06PM
Thanks, I can see your approach, but it didn't work and even if it did I would end up with some big holes, when the maximum should be 5mm diameter
Just to clarify, the radius of each hole should increase by 0.05 and the distance between holes should increase by 0.05.
Holes should have a diameter in the range 3.0 to 5.0 in steps of 0.1mm.
Hope thats clearer
Thanks for your help.
October 11, 2015 02:29PM
I am not sure if I understand exactly what you are trying to do. But if you are looking for this kind of object
here is how I constructed it:
module holes(
   n,     // number of holes
   r,     // initial radius
   step,  // increase step for radius
   gap,   // gap between holes
   height,     // height of holes
  translate([r,0,0])cylinder(r=r,h=height);
  if(n>1)translate([2*r+gap,0,0])holes(n-1,r+step,step,gap,height);
module BlockOfHoles(
   height,     // height of block
   margin,// margin outside holes
   difference(){
     cube([2*margin+(2*r+(n-1)*step)*n+(n-1)*gap,2*(r+(n-1)*step+margin),height]);
     translate([margin,r+(n-1)*step+margin,-1])holes(n,r,step,gap,height+2,$fn=24);
BlockOfHoles(n=10,r=1,step=1,gap=0.5,height=10,margin=1);
In your case for holes ranging from 3.0 to 5.0mm with 0.1m increment step and 0.05mm gap, the call would be
BlockOfHoles(n=21,r=1.5,step=0.05,gap=0.05,height=3,margin=1);
October 11, 2015 03:09PM
@enif Thank you that will do nicely
October 11, 2015 05:14PM
appjaws1
Hope thats clearer
Sorry, typo in 4th line. The final 5*i should be 0.05*i.
October 12, 2015 05:06AM
@dc42 Thanks for this, I like a small solution but it's not quite right yet.
difference(){
cube([200,18,3]);
for(i=[0:19]){
translate([5 + 5*i, 6+0.05*i, -0.1]) cylinder(h=4,r=3.05 + 0.05*i);
This is what I tried and as you can see the gaps between holes are reducing as the holes get larger. What I wanted was the gap between holes to remain the same.
difference(){
cube([200,18,3]);
for(i=[0:19]){
translate([5 + 10*i+3.05 + 0.05*i, 5+0.05*i, -0.1]) cylinder(h=4,r=3.05 + 0.05*i);
Any thoughts?
October 12, 2015 06:17AM
I think you need to increase the X coordinate quadratically. Something like this:
difference(){
cube([200,18,3]);
for(i=[0:19]){
translate([8 + 10*i + 0.1*i*i, 5+0.05*i, -0.1]) cylinder(h=4,r=3.05 + 0.05*i);
October 12, 2015 08:28AM
NumHoles = 20; // Number of holes
Gap = 2; // Gap between holes
First=5; // Radius of first hole
Increase=0.05; // Radius size increase per hole
Margin=5; // Border around block
HolesX=2*(NumHoles*First)+(NumHoles-1)*(Gap+NumHoles*Increase); // Total X length of holes
HolesY=2*(First+(NumHoles-1)*Increase); // Diameter of largest hole
difference()
translate([-Margin-First,-Margin-HolesY/2,0])
cube ([2*Margin+HolesX,2*Margin+HolesY,5]);
Holes();
module Holes()
for(i=[0:NumHoles-1])
translate([i*(Gap+2*First+i*Increase),0,-500])
cylinder(r=First+i*Increase, h=1000, $fn=20);
October 12, 2015 08:29AM
I thought I had managed to solve this but running it shows that the smaller the hole the larger the gap
gap=4;
difference(){
cube([200,18,3]);
for(i=[0:19]){
translate([gap*i+((3.05 + 0.05*i)*2)+((3.05 + 0.05*i+1)*2)+gap*i, 5+0.05*i, -0.1]) cylinder(h=4,r=3.05 + 0.05*i);
This is yours which shows the smaller the hole the smaller the gap
gap=6;
difference(){
cube([200,18,3]);
for(i=[0:19]){
translate([8 + gap*i + 0.1*i*i, 5+0.05*i, -0.1]) cylinder(h=4,r=3.05 + 0.05*i);
I'm just getting confused now, the solution lies somewhere in between but I can't see it
October 12, 2015 08:41AM
appjaws1
My algorithm works fine (try it in my previous post): (NumHoles=total number of holes,First=first hole radius, Gap=gap between holes, Increase=radius increase in each hole size)
October 12, 2015 08:56AM
Thank you Dave, perfect.
