Matrix Inversion
Posted by lhartmann
Matrix Inversion
June 11, 2016 11:47AM
Sometime ago I wrote a small set of functions for construction and use transformation matrices, including matrix inversion. Here is the code: [github.com]
Matrix inversion code works most of the time, except I just detected a bug I can not solve. A simple dual rotation matrix, 90º around Y then 90º around Z, is yielding nan+inf on all elements of the inverse. Works nicely for other angles, though...
M = m4rz(90) * m4ry(90); // Rotates around Y first, then Z
Minv = m4inv(M); // Fails
I managed to narrow it down to m4inv_solve(...) which does diagonal zero detection.
M = m4rz(90)*m4ry(90); // Test matrix
echo( // Failing
    m4inv_solve(0, // Solve row 0: Detect diagonal zero, swap rows, calls solve2(...).
        m4inv_mx(M) // Expand to Row-Reduced Echelon Format
echo( // Working by bypassing m4inv_solve(...)
    m4inv_solve2(0, // Solve row 0 (normalize, scale and subtract from all other rows)
        m4inv_rowswap(0,2, // Swap rows 0 and 2 by hand
I looked at the code for m4inv_solve(...) for a while, but don't get why it is failing... Any ideas?
// Solve one step, ensure nonzero at diagonal element.
function m4inv_zero(x) = abs(x) < 1e-5;
function m4inv_solve(i,mx) =
                 !m4inv_zero(mx[ i ][i  ]) ? m4inv_solve2(i,                     mx ) :
        i+1<4 && !m4inv_zero(mx[ i ][i+1]) ? m4inv_solve2(i, m4inv_rowswap(i,i+1,mx)) :
        i+2<4 && !m4inv_zero(mx[ i ][i+2]) ? m4inv_solve2(i, m4inv_rowswap(i,i+2,mx)) :
        i+3<4 && !m4inv_zero(mx[ i ][i+3]) ? m4inv_solve2(i, m4inv_rowswap(i,i+3,mx)) :
        m4identity(); // Singular matrix, reset to identity
Re: Matrix Inversion
June 11, 2016 09:28PM
Solved: I mixed up row and column indexes while looking for a suitable row for swapping...
                 !m4inv_zero(mx[i  ][ i ]) ? m4inv_solve2(i,                     mx ) :
        i+1<4 && !m4inv_zero(mx[i+1][ i ]) ? m4inv_solve2(i, m4inv_rowswap(i,i+1,mx)) :
        i+2<4 && !m4inv_zero(mx[i+2][ i ]) ? m4inv_solve2(i, m4inv_rowswap(i,i+2,mx)) :
        i+3<4 && !m4inv_zero(mx[i+3][ i ]) ? m4inv_solve2(i, m4inv_rowswap(i,i+3,mx)) :
Edited 1 time(s). Last edit at 06/11/2016 09:29PM by lhartmann.
