Help with rounded edge December 09, 2016 05:22PM |
Variable size back box lid. Use the same dimensions as the box you
programmed earlier. You do not need to specify height as it will
use wall thickness to determine it.
Input format:
lid(length,width,wall thickness,screw hole diameter);
$fn=100; //# of facets in curves
lid(100,90,3,3);
module lid(xdim,ydim,wall,screw)
xdim1 = xdim + (wall*2) + ((screw + 6) * 2); //full box x dimension
ydim1 = ydim + (wall*2) + ((screw + 6) * 2); //full box y dimension
difference() //screw holes
union() //bottom and top halves of lid
translate([wall+0.2,wall+0.2,0])
roundedrect((xdim1 - (wall*2) - 0.4),(ydim1 - (wall*2) - 0.4),wall-0.2,(wall-1)); //inner lid
translate([0,0,wall-0.3])
roundedrect(xdim1,ydim1,wall,(wall-1)); //outer lid
translate([(wall + 3 + (screw / 2)),(wall + 3 + (screw / 2)),0])
cylinder(wall,(screw/2),(screw/2)); //X0, Y0 hole
translate([(wall + 3 + (screw / 2)),(wall + 3 + (screw / 2)),wall])
cylinder(wall,screw/2,(screw * 1.5)); //X0 Y0 hole flare
translate([(wall + 3 + (screw / 2)),((wall*2) + ydim + screw + 9 + (screw/2)),0])
cylinder(wall,(screw/2),(screw/2)); //X0, Y+ hole
translate([(wall + 3 + (screw / 2)),((wall*2) + ydim + screw + 9 + (screw/2)),wall])
cylinder(wall,screw/2,(screw * 1.5)); //X0 Y+ hole flare
translate([(wall + xdim + screw + 9 + (screw/2) + 0.1),(wall + 3 + (screw / 2)),0])
cylinder(wall,(screw/2),(screw/2)); //X+, Y0 hole
translate([(wall + xdim + screw + 9 + (screw/2) + 0.1),(wall + 3 + (screw / 2)),wall])
cylinder(wall,screw/2,(screw * 1.5)); //X+ Y0 hole flare
translate([(wall + xdim + screw + 9 + (screw/2) + 0.1),((wall*2) + ydim + screw + 9 + (screw/2)),0])
cylinder(wall,(screw/2),(screw/2)); //X+, Y+ hole
translate([(wall + xdim + screw + 9 + (screw/2) + 0.1),((wall*2) + ydim + screw + 9 + (screw/2)),wall])
cylinder(wall,screw/2,(screw * 1.5)); //X+ Y+ hole flare
LCD is a module to create a hole for an LCD in the lid. Specify the
width (X) and the height (y) and any offest from center required (X and Y).
A negative offset takes you closer to zero on that axis. If no offest is
required, use zero.
Format: LCD(width,height,xoffset,yoffset,xdim1,ydim1,wall);
lcd(41.5,13.5,-3,20,xdim1,ydim1,wall);
LCDHoles is the mounting holes for the LCD (if necessary). Specify the
X and Y dimensions between hole centers, the offsets used for the LCD
window, and the hole diameter.
Format: lcdholes(xdim,ydim,xoffset,yoffset,hole diameter,xdim1,ydim1,wall);
//lcdholes(30.48,17.78,-3,20,3,xdim1,ydim1,wall);
Holes is a module that creates a single hole, Specify x,y location
and the diameter of the hole. Repeat the call as many times as you
need.
holes((xdim1 / 2),35,14,wall); //pushbutton hole
holes(30,35,7,wall); //power switch
module roundedrect(xdim2,ydim2,zdim2,rdim)
hull()
translate([rdim,rdim,0])
cylinder(zdim2,rdim,rdim); //left front
translate([rdim,ydim2,0])
cylinder(zdim2,rdim,rdim); //left rear
translate([xdim2-rdim,rdim,0])
cylinder(zdim2,rdim,rdim); //right front
translate([xdim2-rdim,ydim2,0])
module lcd(xdim2,ydim2,xoffset,yoffset,xtot2,ytot2,wall2)
side = ((xtot2 - xdim2) / 2) + xoffset + wall2;
up = ((ytot2 - ydim2) / 2) + yoffset + wall2;
translate([side,up,0])
cube([xdim2,ydim2,(wall2 * 2) +1]);
module lcdholes(xdim3,ydim3,xoffset1,yoffset1,hole,xtot1,ytot1,wall1)
side1 = ((xtot1 - xdim3) / 2) + xoffset1;
up1 = ((ytot1 - ydim3) / 2) + yoffset1;
translate([side1,up1,0])
cylinder(wall1,hole / 2,hole / 2); //X0 Y0 hole
translate([side1,up1,wall1])
cylinder(wall1,hole / 2,hole * 1.5); //X0 Y0 hole flare
translate([side1,wall1 + up1 + ydim3,0])
cylinder(wall1,hole / 2,hole / 2); //X0 Y+ hole
translate([side1,wall1 + up1 + ydim3,wall1])
cylinder(wall1,hole / 2,hole * 1.5); //X0 Y+ hole flare
translate([(wall1 + side1 + xdim3),up1,0])
cylinder(wall1,hole / 2,hole / 2); //X+ Y0 hole
translate([(wall1 + side1 + xdim3),up1,wall1])
cylinder(wall1,hole / 2,hole * 1.5); //X+ Y0 hole flare
translate([(wall1 + side1 + xdim3),wall1 + up1 + ydim3,0])
cylinder(wall1,hole / 2,hole / 2); //X+ Y+ hole
translate([(wall1 + side1 + xdim3),wall1 + up1 + ydim3,wall1])
cylinder(wall1,hole / 2,hole * 1.5); //X+ Y+ hole flare
module holes(x2,y2,d2,wall3)
translate([x2,y2,0])
cylinder((wall3 * 2) + 1,(d2 /2),(d2 /2));
Re: Help with rounded edge December 09, 2016 10:32PM |
Re: Help with rounded edge December 10, 2016 01:41AM |
Re: Help with rounded edge December 10, 2016 04:01AM |
// construct a rectangle with rounded corners but a flat bottom
module FlatBottomRoundRect(length,width,height,radius){
// iterate over the 4 corners
hull()for(sx=[-1,1])for(sy=[-1,1])scale([sx,sy,1]){
// lower cylindric part
if(height>radius)translate([length/2-radius,width/2-radius,0])
cylinder(r=radius,h=height-radius);
// upper spheric part
intersection(){
// sphere
translate([length/2-radius,width/2-radius,height-radius])
sphere(r=radius);
// clip shere at bottom plane
if(height<2*radius)translate([length/2-radius,width/2-radius,0])
cylinder(r=radius,h=height);
Re: Help with rounded edge December 10, 2016 02:16PM |
Replace
So minkowski the flat cube with a small sphere, (After the merge, it will be bigger 1/2 of the diameter)
Scale down 1/2 of the diameter of the sphere
cut off (difference) a bigger cube of the side that should not be rounded
Add all other parts
minkowski() {
cube(50);
difference() {
sphere($fn=20, 10);
translate([-10,-10,-20]) cube(20);
Re: Help with rounded edge December 10, 2016 04:30PM |
