Feature request January 16, 2017 07:55AM |
Re: Feature request January 22, 2017 04:21PM |
Actually, it might be better if minkowski() was modified to not automatically union() the original object into the result. Perhaps by passing an optional parameter to it?
// Minkowski difference??? of a given object with second given object, similar to the existing minkowski() function.
module minkowskiDifference() {
difference() {
children(0);
minkowski() {
children(0);
children(1);
// Shell of a given object with second given object, similar to the existing minkowski() function.
module minkowskiIntersection() {
intersection() {
children(0);
children(1)
children(0);
Re: Feature request January 23, 2017 07:05AM |
Re: Feature request January 23, 2017 03:59PM |
difference() {
minkowski() {
children(0);
children(1);
children(0);
intersection() { // To show that the minkowski difference is hollow inside
cube([5, 4, 10]);
sphere(1, center=true);
cube([5,4,10], center=true);
Re: Feature request January 25, 2017 11:19PM |
Re: Feature request January 26, 2017 08:35AM |
frankvdh
I think the following implements Minkowski difference (if I understand correctly what that is). Or are there subtleties I've missed?
Re: Feature request January 26, 2017 09:49AM |
// Implementation of a Minkowski difference using
// the Minkowski sum on a negative ("hole") of the initial object
module minkdiff(){
// Subtract from the original object a bigger object with a Minkowski summed (->reduced) hole
difference(){
children(0);
// Minkowski sum of the negative initial object
minkowski(){
// make a hollow object with a hole that corresponds to the initial object
difference(){
// increase the size of initial object using Minkowski sum
minkowski(){
children(0);
cube([1,1,1],true);
// now remove initial object
children(0);
children(1);
// now try it out, to see if it works...
%cylinder(r=10,h=10);
%color("red",0.5)translate([-10,0,10])cube([10,1,1],true);
minkdiff(){
