how can i create a polygon that would encompass all this shapes? February 11, 2018 03:01PM |
Re: how can i create a polygon that would encompass all this shapes? February 11, 2018 03:32PM |
Re: how can i create a polygon that would encompass all this shapes? February 11, 2018 04:31PM |
Re: how can i create a polygon that would encompass all this shapes? February 11, 2018 10:27PM |
Re: how can i create a polygon that would encompass all this shapes? February 12, 2018 01:54AM |
Re: how can i create a polygon that would encompass all this shapes? February 12, 2018 02:00AM |
Re: how can i create a polygon that would encompass all this shapes? February 12, 2018 08:09AM |
Re: how can i create a polygon that would encompass all this shapes? February 13, 2018 03:01AM |
Re: how can i create a polygon that would encompass all this shapes? February 13, 2018 10:47AM |
enif
emaayan
it certainly does , now if i could just offset, but i'm guessing i'm gonna have to re-do the function that creates the cells, to use circles and not cylinders so the hull would be 2d..
You could also use projection() to project the hull into a 2D-polygon.
Re: how can i create a polygon that would encompass all this shapes? February 13, 2018 01:36PM |
Re: how can i create a polygon that would encompass all this shapes? February 13, 2018 02:14PM |
Re: how can i create a polygon that would encompass all this shapes? February 14, 2018 05:51AM |
// cell configuration
n=-1; p=1;
simpleOne=[
[p,n,p]
,[p,n,p]
,[p,n,n]
,[p,n]
,[p,n]
,[p]
module batterycase(cells,dia=18,len=65,wall=10,wallz=4){
// cell position of cells[r][c]
function cellpos(r,c)=[(2*$row+($col%2)),2*cos30*$col,0];
// Local module to iterate through all cells
// Variables $row, $col are global, so they can be used in all children
module drawHoles(){
for($row=[0:len(cells)-1])
for($col=[0:len(cells[$row])-1])
translate(radius*cellpos($row,$col)) children();
// Local module to draw a + or -
module pole(s)
{for(a=[0: (s>0?90:180):359])rotate(a)translate([0,-1,0])cube([4,2,1]);}
cos30 = cos(30);
radius=dia/2+0.5;
difference(){
// outer shell
union()drawHoles()
cylinder(r=dia/2+wall,h=len+2*wallz,$fn=6);
// inner cavity
union() translate([0,0,2*wallz])drawHoles()
rotate(30)cylinder(r=dia/2/cos30+1,h=len-2*wallz,$fn=6);
// individual cell cylinders
drawHoles(){
// cell cavity
translate([0,0,-0.1]) cylinder(r=dia/2,h=len+2*wall+0.2);
// show polarity on top and bottom
%translate([0,0,2*wallz+len-1])pole(cells[$row][$col]);
%translate([0,0,-1])pole(-cells[$row][$col]);
// ... and whatever else is needed
batterycase(simpleOne);
Re: how can i create a polygon that would encompass all this shapes? February 14, 2018 08:37AM |
