As the we are in the R&D phase of developing Stereolithography 3D printer. We need SDK for Windows based program (.SDK file to .SVG Vector base).
The SDK file should run in Windows program platform which can handle .stl file with tools such as: rotation, size adjustments/orientation, different type mesh filler, Intelligent support generation add & remove and with multiple STL file that can be import in different size of printing platform, Infill pattern and density, Infill optimization and support.
Also the SDK should be able to Slice the .stl file in different microns and save in one folder in Que batch (.SVG vector format). The file should be saved in encrypted form with decryption of the saved file too.
Let me know how could you help in developing Stereolithography 3D printer for me. Get back to me as soon as possible. Please consider one time fees if necessary for the above points mentioned.
Thank you.
Best Regards,
Kanti Patel ( Technical, Director )
ProtoBay
Kp1957aver@gmail.com
P.kanti@protobay.co.in
P.nimit93@gmail.com
+91 9324064056
