Megatronics v3 (echo:busy: processing) March 10, 2017 12:16PM |
18:09:38.434 : Serial com errorystem.IO.Ports.SerialErrorReceivedEventArgs 18:09:39.661 : Printer reset detected - initalizing 18:09:39.661 : start 18:09:39.661 : echo:Marlin 1.1.0-RC7 18:09:39.661 : echo: Last Updated: 2016-07-31 12:00 | Author: (RebeliX) 18:09:39.661 : Compiled: Mar 10 2017 18:09:39.662 : echo: Free Memory: 4423 PlannerBufferBytes: 1232 18:09:39.662 : echo:Hardcoded Default Settings Loaded 18:09:39.662 : echoteps per unit: 18:09:39.662 : echo: M92 X160.00 Y160.00 Z800.00 E830.00 18:09:39.662 : echo:Maximum feedrates (mm/s): 18:09:39.662 : echo: M203 X300.00 Y300.00 Z2.50 E25.00 18:09:39.662 : echo:Maximum Acceleration (mm/s2): 18:09:39.662 : echo: M201 X3000 Y3000 Z100 E10000 18:09:39.662 : echo:Accelerations: P=printing, R=retract and T=travel 18:09:39.663 : echo: M204 P3000.00 R3000.00 T3000.00 18:09:39.663 : echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s) 18:09:39.663 : echo: M205 S0.00 T0.00 B20000 X5.00 Z0.40 E5.00 18:09:39.663 : echo:Home offset (mm) 18:09:39.663 : echo: M206 X0.00 Y0.00 Z0.00 18:09:39.663 : echo:Material heatup parameters: 18:09:39.663 : echo: M145 S0 H180 B60 F0 18:09:39.664 : echo: M145 S1 H220 B90 F0 18:09:39.664 : echoID settings: 18:09:39.664 : echo: M301 P13.27 I0.83 D53.16 18:09:39.664 : echo:Filament settings: Disabled 18:09:39.664 : echo: M200 D3.00 18:09:39.664 : echo: M200 D0 18:09:39.818 : N1 M110*34 18:09:39.818 : N2 M115*36 18:09:39.818 : N3 M105*36 18:09:39.818 : N4 M114*35 18:09:39.831 : N5 M111 S6*98 18:09:39.831 : N6 T0*60 18:09:39.831 : N7 M20*22 18:09:39.832 : N8 M80*19 18:09:39.832 : N9 M105*46 18:09:42.665 : ok 18:09:42.774 : FIRMWARE_NAME:Marlin 1.1.0-RC7 (Github) SOURCE_CODE_URL:[github.com] PROTOCOL_VERSION:1.0 MACHINE_TYPE:RebeliX X2 EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff 18:09:42.775 : N10 M220 S100*80 18:09:42.775 : ok 18:09:42.775 : N11 M221 S100*80 18:09:42.776 : ok T:22.1 /0.0 B:22.5 /0.0 @:0 B@:0 18:09:42.776 : N12 M111 S6*84 18:09:42.777 : X:0.00 Y:0.00 Z:0.00 E:0.00 Count X: 0 Y:0 Z:0 18:09:42.777 : ok 18:09:42.777 : N13 T0*8 18:09:42.868 : echoEBUG:INFO,ERRORS 18:09:42.868 : ok 18:09:42.868 : echo:Active Extruder: 0 18:09:42.868 : ok 18:09:42.868 : ok 18:09:42.868 : ok 18:09:42.869 : ok T:23.1 /0.0 B:22.5 /0.0 @:0 B@:0 18:09:42.869 : ok 18:09:42.869 : ok 18:09:42.869 : echoEBUG:INFO,ERRORS 18:09:42.869 : ok 18:09:42.869 : echo:Active Extruder: 0 18:09:42.869 : ok 18:09:42.884 : N14 M105*18 18:09:42.948 : ok T:23.1 /0.0 B:22.5 /0.0 @:0 B@:0 18:09:43.070 : N15 G28*39 18:09:45.089 : echo:busy: processing 18:09:45.949 : N16 M105*16 18:09:47.086 : echo:busy: processing 18:09:49.008 : N17 M105*17 18:09:49.083 : echo:busy: processing 18:09:51.081 : echo:busy: processing 18:09:52.067 : N18 M105*30 18:09:53.078 : echo:busy: processing 18:09:55.075 : echo:busy: processing 18:09:55.134 : N19 M105*31 18:09:57.088 : echo:busy: processing 18:09:58.191 : N20 M105*21 18:09:59.086 : echo:busy: processing 18:10:01.083 : echo:busy: processing 18:10:01.257 : N21 M105*20 18:10:03.080 : echo:busy: processing 18:10:04.318 : N22 M105*23 18:10:05.093 : echo:busy: processing 18:10:07.091 : echo:busy: processing 18:10:07.384 : N23 M105*22 18:10:09.088 : echo:busy: processing 18:10:11.085 : echo:busy: processing 18:10:13.082 : echo:busy: processing 18:10:15.096 : echo:busy: processing 18:10:17.093 : echo:busy: processing 18:10:19.090 : echo:busy: processing 18:10:21.086 : echo:busy: processing 18:10:23.083 : echo:busy: processing 18:10:25.096 : echo:busy: processing 18:10:27.094 : echo:busy: processing 18:10:29.091 : echo:busy: processing 18:10:31.087 : echo:busy: processing 18:10:33.084 : echo:busy: processing 18:10:35.082 : echo:busy: processing 18:10:37.095 : echo:busy: processing 18:10:39.092 : echo:busy: processing
Re: Megatronics v3 (echo:busy: processing) March 10, 2017 06:27PM |
