# generated by Slic3r 0.9.9 on Thu Aug 15 22:32:18 2013
avoid_crossing_perimeters = 0
bed_size = 200,200
bed_temperature = 0
bottom_solid_layers = 3
bridge_acceleration = 0
bridge_fan_speed = 100
bridge_flow_ratio = 1
bridge_speed = 50
brim_width = 0
complete_objects = 0
cooling = 1
default_acceleration = 0
disable_fan_first_layers = 1
duplicate = 1
duplicate_distance = 6
duplicate_grid = 1,1
end_gcode = G91 ; relative\nG1 Z10 F200 ; 10mm up\nG1 E-10 F100 ; 4mm reverse\nG28 X0 ; home X axis\nG28 Y0 ; home Y axis\nG1 Y100 F3000\nM109 S170 ; wait for 170C\nM302 ; cold extrusion on\nG1 E-10 F200 ; reverse filament\nM302 S150 ; cold extrusion off\nM84 ; disable motors\nM81 ; off
external_perimeter_speed = 90%
external_perimeters_first = 0
extra_perimeters =
extruder_clearance_height = 20
extruder_clearance_radius = 20
extruder_offset = 0x0
extrusion_axis = E
extrusion_multiplier = 1
extrusion_width = 0
fan_always_on = 0
fan_below_layer_time = 60
filament_diameter = 1.75
fill_angle = 45
fill_density = 0.2
fill_pattern = rectilinear
first_layer_bed_temperature = 0
first_layer_extrusion_width = 200%
first_layer_height = 95%
first_layer_speed = 20
first_layer_temperature = 180
g0 = 0
gap_fill_speed = 30
gcode_arcs = 0
gcode_comments = 0
gcode_flavor = reprap
infill_acceleration = 0
infill_every_layers = 1
infill_extruder = 1
infill_extrusion_width = 0
infill_first = 0
infill_only_where_needed = 0
infill_speed = 50
layer_gcode =
layer_height = 0.25
max_fan_speed = 100
min_fan_speed = 35
min_print_speed = 10
min_skirt_length = 0
notes =
nozzle_diameter = 0.4
only_retract_when_crossing_perimeters = 1
output_filename_format = [input_filename_base].gcode
perimeter_acceleration = 0
perimeter_extruder = 1
perimeter_extrusion_width = 0
perimeter_speed = 50
perimeters = 2
post_process =
print_center = 100,80
raft_layers = 0
randomize_start =
resolution = 0
retract_before_travel = 2
retract_layer_change =
retract_length = 1.5
retract_length_toolchange = 10
retract_lift = 0
retract_restart_extra = 0.3
retract_restart_extra_toolchange = 0
retract_speed = 40
rotate = 0
scale = 1
skirt_distance = 6
skirt_height = 1
skirts = 2
slowdown_below_layer_time = 30
small_perimeter_speed = 40%
solid_fill_pattern = rectilinear
solid_infill_below_area = 70
solid_infill_every_layers = 0
solid_infill_extrusion_width = 0
solid_infill_speed = 80%
start_gcode = G28 Z0 \nG1 Z2 F200\nG28\nG1 Z2 F200
support_material =
support_material_angle = 0
support_material_enforce_layers = 0
support_material_extruder = 1
support_material_extrusion_width = 0
support_material_interface_layers = 0
support_material_interface_spacing = 0
support_material_pattern = rectilinear
support_material_spacing = 2.5
support_material_speed = 50
support_material_threshold = 0
temperature = 180
threads = 6
toolchange_gcode =
top_infill_extrusion_width = 0
top_solid_infill_speed = 80%
top_solid_layers = 3
travel_speed = 80
use_relative_e_distances = 0
vibration_limit = 9000
z_offset = 0
