Heatbed sa nahreje na cca 60-80°C a potom vypne September 17, 2013 05:17PM |
Re: Heatbed sa nahreje na cca 60-80°C a potom vypne September 17, 2013 05:22PM |
Re: Heatbed sa nahreje na cca 60-80°C a potom vypne September 17, 2013 06:06PM |
Re: Heatbed sa nahreje na cca 60-80°C a potom vypne September 17, 2013 06:11PM |
Re: Heatbed sa nahreje na cca 60-80°C a potom vypne September 18, 2013 04:52AM |
Re: Heatbed sa nahreje na cca 60-80°C a potom vypne September 18, 2013 12:28PM |
Re: Heatbed sa nahreje na cca 60-80°C a potom vypne September 18, 2013 01:36PM |
uz si ji sehnal???
a podle PDFka to taky tak nak odpovida
Re: Heatbed sa nahreje na cca 60-80°C a potom vypne September 18, 2013 01:54PM |
Re: Heatbed sa nahreje na cca 60-80°C a potom vypne September 18, 2013 02:22PM |
Re: Heatbed sa nahreje na cca 60-80°C a potom vypne September 18, 2013 02:52PM |
Re: Heatbed sa nahreje na cca 60-80°C a potom vypne September 18, 2013 03:12PM |
Re: Heatbed sa nahreje na cca 60-80°C a potom vypne September 18, 2013 03:29PM |
Re: Heatbed sa nahreje na cca 60-80°C a potom vypne September 18, 2013 03:37PM |
Re: Heatbed sa nahreje na cca 60-80°C a potom vypne September 18, 2013 03:42PM |
dival sem se na zapojeni na wiki.
Re: Heatbed sa nahreje na cca 60-80°C a potom vypne September 18, 2013 03:49PM |
Re: Heatbed sa nahreje na cca 60-80°C a potom vypne September 18, 2013 04:09PM |
Re: Heatbed sa nahreje na cca 60-80°C a potom vypne September 18, 2013 04:10PM |
Re: Heatbed sa nahreje na cca 60-80°C a potom vypne September 18, 2013 04:28PM |
nikdo nejsme dokonalej
konrketne sem to schrnul takto: a jelikoz nejsou idealni konstrukteri cehokoliv, ani idealni soucastky, existuji pojistky
Re: Heatbed sa nahreje na cca 60-80°C a potom vypne September 18, 2013 05:51PM |
Re: Heatbed sa nahreje na cca 60-80°C a potom vypne September 19, 2013 01:35AM |
Re: Heatbed sa nahreje na cca 60-80°C a potom vypne September 19, 2013 03:24AM |
Re: Heatbed sa nahreje na cca 60-80°C a potom vypne September 19, 2013 03:35AM |
Re: Heatbed sa nahreje na cca 60-80°C a potom vypne September 19, 2013 04:13AM |
- aby se ti neprepalilo vynuti motoru pri zaseknuti hridele, nebo vetsim odporu na hridely, vklada se do privodu napajeni takovato obdobna pojistka.
teda aspon o te troube to vim.
Re: Heatbed sa nahreje na cca 60-80°C a potom vypne September 19, 2013 04:18AM |
Re: Heatbed sa nahreje na cca 60-80°C a potom vypne September 22, 2013 08:34AM |
Re: Heatbed sa nahreje na cca 60-80°C a potom vypne September 22, 2013 11:01AM |
) a vzpominal na dny na elektroprumce, tak odpor medi se s narustajici teplotou zvetsuje, tedy by mel protekajici proud spis klesat... ale rad se necham poucit, pokud je ma uvaha zcestna
Re: Heatbed sa nahreje na cca 60-80°C a potom vypne September 22, 2013 03:26PM |
Re: Heatbed sa nahreje na cca 60-80°C a potom vypne November 16, 2013 12:50PM |
