[problemy] - kalibrace October 27, 2013 07:49PM |
Moderator Registered: 13 years ago Posts: 1,038 |
Re: [problemy] - kalibrace December 20, 2013 05:10AM |
Re: [problemy] - kalibrace December 20, 2013 08:48AM |
Re: [problemy] - kalibrace December 20, 2013 08:55AM |
to muze bejt:
- testnul sem to jednou a neni dobre, kdyz se najednou motor zastavi naraz a zmeni smer
Re: [problemy] - kalibrace December 20, 2013 08:57AM |
Re: [problemy] - kalibrace December 20, 2013 09:34AM |
Re: [problemy] - kalibrace December 20, 2013 09:47AM |
Re: [problemy] - kalibrace December 20, 2013 10:08AM |
--------------- -------------- ------------- ------------- smer Y ---->
Re: [problemy] - kalibrace December 20, 2013 02:32PM |
Re: [problemy] - kalibrace December 20, 2013 02:43PM |
Re: [problemy] - kalibrace December 20, 2013 03:49PM |
Re: [problemy] - kalibrace December 20, 2013 03:54PM |
Re: [problemy] - kalibrace December 20, 2013 04:14PM |
Re: [problemy] - kalibrace December 20, 2013 04:27PM |
Re: [problemy] - kalibrace December 20, 2013 05:37PM |
Re: [problemy] - kalibrace December 21, 2013 07:02AM |
Re: [problemy] - kalibrace December 21, 2013 05:54PM |
Re: [problemy] - kalibrace December 21, 2013 06:41PM |
Re: [problemy] - kalibrace December 23, 2013 05:00AM |
130 travel 70 infill a 30 perimetrs a tisknu [www.thingiverse.com] a bížim se horním mu oblouku, nic neujíždí a hezký EDIT: ješte jsem povolil křížově y tyče(jenom trochu)|
Re: [problemy] - kalibrace July 29, 2014 01:59PM |
Re: [problemy] - kalibrace July 29, 2014 02:24PM |
Re: [problemy] - kalibrace July 29, 2014 02:42PM |
Re: [problemy] - kalibrace July 30, 2014 09:44AM |
Re: [problemy] - kalibrace September 03, 2014 08:51AM |
Re: [problemy] - kalibrace September 03, 2014 10:10AM |
Re: [problemy] - kalibrace September 03, 2014 10:52AM |
Re: [problemy] - kalibrace September 03, 2014 11:02AM |
Re: [problemy] - kalibrace September 03, 2014 08:19PM |
Re: [problemy] - kalibrace September 04, 2014 02:04PM |
Re: [problemy] - kalibrace September 05, 2014 07:23AM |
Mailen
Takže asi vyřešeno, pravdu raptik má, jako obvykle :-) Marlin počítá s nulovou výškou při sepnuti Z koncáku, Proto když jsem hlavu zkalibroval na tloušťku papíru (asi někdy i víc) tak při použití vrstvy třeba 0.4 se to vlastně ještě o tolik zvedlo a proto to tisklo v luftě. Takže jsem to nakalibroval přímo na sklo a teď po 5 výtisku můžu říct, že to bylo ono. tiskne to dobře. Drivery mám skoro studené, za to motory po hodině tisku docela hycujou, ale myslím že je to normál. Ale je problém z vrstvy typu bridge, měl jsem objednaný vzorek od Asperie 2,9mm Pla, výtisky parádní i bridge. Teď jsem objednal kilo a je to nějaké divné, Na cívce napsáno 3mm a teplota 210. Tisknu ji na 200 s nastavením 2,9, jelikož když skončím tisk tak je drát zhruba někde nad topnou částí, možná tak 2 - 3cm a vlastně to z trysky po celou dobu tisku jenom teče. Z jejich doporučeným nastavením se to jakoby lepilo a kolem hlavy se dělaly žmolky a při retrakci byly kapky, což vzorek nedělal,Že by Mladeč? Jinak dík za odpovědi, pomohly mi.
