Re: Posunuti v ose x nevim uz co... January 22, 2016 03:45PM |
Re: Posunuti v ose x nevim uz co... January 22, 2016 03:49PM |
Moderator Registered: 12 years ago Posts: 1,038 |
Spoach
Jo a me se to nestava na slic3ru, ja pouzivam cura.
Re: Posunuti v ose x nevim uz co... January 23, 2016 09:13AM |
Re: Posunuti v ose x nevim uz co... January 23, 2016 01:30PM |
Re: Posunuti v ose x nevim uz co... January 23, 2016 01:33PM |
Re: Posunuti v ose x nevim uz co... January 23, 2016 01:56PM |
tisknu pri 60mm/s, když to snížím třeba na 40 tak je to poměrně v cajku...
Re: Posunuti v ose x nevim uz co... January 23, 2016 02:00PM |
Re: Posunuti v ose x nevim uz co... January 23, 2016 02:07PM |
Re: Posunuti v ose x nevim uz co... January 23, 2016 02:30PM |
Re: Posunuti v ose x nevim uz co... January 23, 2016 04:34PM |
Re: Posunuti v ose x nevim uz co... January 23, 2016 04:54PM |
Re: Posunuti v ose x nevim uz co... January 23, 2016 05:55PM |
Re: Posunuti v ose x nevim uz co... January 24, 2016 12:42PM |
Re: Posunuti v ose x nevim uz co... January 24, 2016 05:26PM |
Re: Posunuti v ose x nevim uz co... January 25, 2016 12:30PM |
Re: Posunuti v ose x nevim uz co... February 02, 2016 02:36PM |
Re: Posunuti v ose x nevim uz co... February 02, 2016 02:37PM |
Re: Posunuti v ose x nevim uz co... February 02, 2016 05:25PM |
Re: Posunuti v ose x nevim uz co... February 02, 2016 06:29PM |
Re: Posunuti v ose x nevim uz co... February 03, 2016 03:50AM |
Re: Posunuti v ose x nevim uz co... February 03, 2016 04:35AM |
Spoach
Jeste se zeptam kdyz sem kalibroval extruder tak mi zajede presne tolik plastu kolik dam, ale kdyz jennazhavena a s tryskou tak mi cca pri 10 cm materialu projede jen 8,5. Ale bez trysky projede presne 10 takze mam spatne nakalibrovany extruder?
Jeste dotaz kde se v marlin da vypnout sledovani endstopu? Kdyby mi ten problem delal endstop
Re: Posunuti v ose x nevim uz co... February 03, 2016 04:41AM |
Spoach
Re: Posunuti v ose x nevim uz co... February 03, 2016 05:27AM |
Re: Posunuti v ose x nevim uz co... February 03, 2016 06:34AM |
Re: Posunuti v ose x nevim uz co... February 03, 2016 07:45AM |
Spoach
Nn nemam stahl jsem si cistej marlin, a upravil vsechny hodnoty na rebelixe. Nebo lepe receno na moji verzi tiskarny.
Oka takze upravit tak at to slape s nazhavenym hotendem.
Ta osa x se mi zda ze se zpravila. Nevim uvidim po par vytiscich. Ale musel jsem dat novy driver. Nastesti mi z ciny doslo 5driveru, tak byl jeden plonkovni.
Dal jsem tisk a pridal jsem o 10 % vice filamentu tak uvidime co to udela a podle toho bych potom znovu odkrokoval extruder. Jo filament mam mladec pla, prodavali to v jrc ale pod jinym vyrobcem a pod nalepkou ejhle.
Jo rychlost tisku byla 44mm/s
Re: Posunuti v ose x nevim uz co... February 03, 2016 12:41PM |
Re: Posunuti v ose x nevim uz co... February 14, 2016 02:07PM |
Re: Posunuti v ose x nevim uz co... February 14, 2016 02:31PM |
Spoach
Tak se mi to projevilo zase a napadla me vec jestli to nemuze byt motorem na ose x mam tam sx17 1003 a ten ma kroutici moment poze 0.3 tak jestli neztraci kroky proto ze je to na nej moc tezke. Kazdopadne jsem si ted obednal sx17 0905 ten je dvakrat silnejsi. Kdyz vezmu v potaz tak stolik je tezsi na utazeni kdyz je tam vytisk a mam tam 3mm silny nerezovy plech. Co myslite?
) a motor kolem 0.4 s tim nemel problem (nakej cina, pozdeji to hnal i SX17-1005)
Re: Posunuti v ose x nevim uz co... February 14, 2016 02:41PM |
Re: Posunuti v ose x nevim uz co... February 14, 2016 04:35PM |
