extruder E3D April 01, 2016 03:28PM |
Re: extruder E3D April 04, 2016 04:53AM |
Re: extruder E3D April 04, 2016 11:38AM |
Ahoj problém se zadrháváním filamentu jsem vyřešil (dust filtrem)teď mě vrtá hlavou proč když tisknu na 0,1 nebo 0,2 mm je tisk nekvalitníQuote
W1mpy
Ahoj,
to je celokov a nebo pouzivas PTFE? Nemas nastavenou moc velkou retrakci? Kdyz pri tisku sahnes na heatbrake (zebra) jsou studeny/vlazny/ horky?
#define DEFAULT_AXIS_STEPS_PER_UNIT {80,80,4000,628} // default steps per unit for Ultimaker #define DEFAULT_MAX_FEEDRATE {1000, 1000, 2, 10} // (mm/sec) #define DEFAULT_MAX_ACCELERATION {500,500,5,50} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for Skeinforge 40+, for older versions raise them a lot. #define DEFAULT_ACCELERATION 500 // X, Y, Z and E max acceleration in mm/s^2 for printing moves #define DEFAULT_RETRACT_ACCELERATION 500 // X, Y, Z and E max acceleration in mm/s^2 for retracts // Offset of the extruders (uncomment if using more than one and relying on firmware to position when changing). // The offset has to be X=0, Y=0 for the extruder 0 hotend (default extruder). // For the other hotends it is their distance from the extruder 0 hotend. // #define EXTRUDER_OFFSET_X {0.0, 20.00} // (in mm) for each extruder, offset of the hotend on the X axis // #define EXTRUDER_OFFSET_Y {0.0, 5.00} // (in mm) for each extruder, offset of the hotend on the Y axis // The speed change that does not require acceleration (i.e. the software might assume it can be done instantaneously) #define DEFAULT_XYJERK 20.0 // (mm/sec) #define DEFAULT_ZJERK 0.4 // (mm/sec) #define DEFAULT_EJERK 5.0 // (mm/sec)
Re: extruder E3D April 04, 2016 12:03PM |
Re: extruder E3D April 04, 2016 12:16PM |
Re: extruder E3D April 04, 2016 01:08PM |
Re: extruder E3D April 04, 2016 01:13PM |
Re: extruder E3D April 04, 2016 01:22PM |
Re: extruder E3D April 04, 2016 01:26PM |
Re: extruder E3D April 04, 2016 02:43PM |
Re: extruder E3D April 04, 2016 03:12PM |
Re: extruder E3D April 04, 2016 04:43PM |
Re: extruder E3D April 05, 2016 03:32AM |
Re: extruder E3D April 05, 2016 08:09AM |
