Re: Octoprint October 17, 2013 09:36AM |
Re: Octoprint October 17, 2013 03:02PM |
me z toho mrskne
Re: Octoprint October 18, 2013 11:20AM |
Nevylucuju ze to treba nedela pretizene raspi tim mjpg streamem, ale pokud to je tim, nemam vratim se zpet k rep-ser.
Re: Octoprint October 18, 2013 04:09PM |
Re: Octoprint October 18, 2013 04:23PM |
Ale jestli mi napises, ze to tam je vyresene, tak se tim nejak prokousu
Re: Octoprint October 18, 2013 04:27PM |
Re: Octoprint October 18, 2013 04:37PM |
kazdopadne jsem do logu nekoukal. To pribrzdovani by tomu mohlo odpovidat. Ale tech 10st rozdilu teploty asi ne. Uvidime.
Re: Octoprint October 19, 2013 04:39AM |
Re: Octoprint October 20, 2013 02:20PM |
docela neprijemne to udelat bez dozoru
Takze jeste budu pokouset ten Octoprint, neda mi to. Z pohledu ovladani je to prehlednejsi, akorat je ten web docela linej. Jinak je to moc hezky udelany.
Re: Octoprint October 20, 2013 02:59PM |
Moderator Registered: 13 years ago Posts: 459 |
Re: Octoprint October 20, 2013 03:38PM |
Re: Octoprint October 21, 2013 01:14AM |
Re: Octoprint October 21, 2013 02:04PM |
V repetierovi je teplota cca spravna v Octoprintu nikoli
Re: Octoprint October 21, 2013 02:38PM |
Re: Octoprint October 21, 2013 03:13PM |
Re: Octoprint October 21, 2013 04:02PM |
Re: Octoprint October 22, 2013 10:48PM |
Re: Octoprint October 23, 2013 02:48AM |
Re: Octoprint October 23, 2013 10:16AM |
Re: Octoprint October 23, 2013 10:20AM |
Octoprint mam upraveny pro Cura, ale jeste se mi nepovedla nainstalovat jako takova, ale nemel jsem moc cas to resit.
Re: Octoprint October 25, 2013 01:59AM |
Mas nejakej link, ze ktereho vychazis?
Re: Octoprint October 25, 2013 08:09AM |
Re: Octoprint October 26, 2013 12:38AM |
sudo apt-get install git python-opengl python-numpy python-serial python-setuptools git clone https:/ /github.com/daid/Cura.git git clone --branch devel https:/ /github.com/foosel/OctoPrint.git cd Cura sudo ./package.sh debian sudo dpkg -i ./scripts/linux/Cura*.deb sudo apt-get -f install cd ../Octoprint ./run
/usr/share/cura/cura.py -i /home/pi/Cura/profiles/standard.ini -s /home/pi/.octoprint/uploads/vlozka.stl -o /home/pi/.octoprint/uploads/vlozka.gcode
Re: Octoprint October 26, 2013 03:42AM |
Re: Octoprint October 26, 2013 09:33AM |
The M109 is added at the start with the following conditions:
* Temperature is set to something else then 0 in Cura.
* There is no {print_temperature} tag in the start code.
So if you add an "M109 S{print_temperature}" after the G28, then it won't do the M109 at the start but at the location of your choosing.
Re: Octoprint October 26, 2013 11:52AM |
Chrome plugin pro Octoprint October 27, 2013 07:25PM |
Re: Chrome plugin pro Octoprint October 28, 2013 07:35AM |
Re: Chrome plugin pro Octoprint October 28, 2013 08:20AM |
Re: Chrome plugin pro Octoprint October 28, 2013 08:31AM |
