Links to open in a new tab November 01, 2013 05:59AM |
Re: Links to open in a new tab November 01, 2013 07:52AM |
Re: Links to open in a new tab November 01, 2013 08:28AM |
Re: Links to open in a new tab November 01, 2013 11:08PM |
Re: Links to open in a new tab November 01, 2013 11:23PM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Links to open in a new tab November 02, 2013 02:04AM |
Re: Links to open in a new tab November 02, 2013 04:21AM |
Cefiar
I think he's suggesting that links to sites outside the forum open in a new tab, not any/all links on the page.
Re: Links to open in a new tab November 02, 2013 12:59PM |
Re: Links to open in a new tab November 02, 2013 01:50PM |
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Links to open in a new tab November 02, 2013 01:56PM |
"Enable BBcode [ quote ]", "If this feature is enabled, then quoting of messages is not done using the standard Phorum method (which resembles email message quoting), but using the BBcode module's quoting method instead. This means that the quoted text is placed within abbcode block.Quote
Two of the advantages of using this quote method is that the quoted message can be styles though CSS code and that no word wrapping is applied to the text.");
Re: Links to open in a new tab November 02, 2013 05:23PM |
Admin Registered: 16 years ago Posts: 13,888 |
Traumflug
P.P.S.: another help message I found there:
Does this sound like hitting the "reply" link would use proper quoting instead of what we have now?
Re: Links to open in a new tab November 02, 2013 07:28PM |
Traumflug
Cefiar
Good point!
Forum moderators: I've looked into the code and found three things:
1. There are settings for the bbcode module. This module apparently defines how links are converted to HTML. Likely they can be accessed on the page listing the modules, there's an "edit" link or something similar.
2. There's a setting "Add 'rel=nofollow' to links that are posted in your forum" with the following choices: 'No', 'Yes, always', 'Yes, to external urls and urls not defined below.'. I think the last of these three is the right one and http:/ /reprap.org, http:/ /www.reprap.org and http:/ /wiki.reprap.org should be in the list of exceptions. Currently, it's apparently set to 'Yes, always', which also applies to internal links and as such drastically lowers the forums' importance on Google searches.
Traumflug
3. There's also a setting "Open links in new window". This one has only yes/no and is off by default. Not sure wether this applies to both, internal and external links, but it might do exactly what we want. Can you please enable it? In case it doesn't work ideal, I can additionally tweak the sources (now that I found where to do this).
Happy clicking through the admin panel! For testing, here's a test message: [forums.reprap.org]
Traumflug
P.S.: the more I work with Phorum, the more I like it. Almost always I attempt to tweak something, I find it already coded, just not enabled. Its primitive appearance is quite a contrast to its feature-richness.
Re: Links to open in a new tab November 03, 2013 04:51AM |
VDX
... I've changed the settings in the BBcode module - check it out ...
Re: Links to open in a new tab November 05, 2013 03:13AM |
