Forum reorganization March 19, 2014 05:17PM |
Re: Forum reorganization March 19, 2014 05:40PM |
Re: Forum reorganization March 19, 2014 06:36PM |
Admin Registered: 12 years ago Posts: 730 |
Good luck getting anyone to agree on what an "official" reprap machine is. Is it a machine from this wiki page? It is a machine from this wiki page? Is it some mishmash of the two, or some combination of other machines??Quote
Buback
official reprap machines
Re: Forum reorganization March 19, 2014 08:39PM |
Re: Forum reorganization March 19, 2014 09:44PM |
and I agree with the assessment. I do my best to streamline the 50% tech support, I really don't care one way or the other about the commercial stuff, and the 5% research is interesting enough that I keep coming back...Quote
iquizzle
In truth, this forum is about 50% used as a place for small businesses to discreetly leverage free advertising and for people to voice opinions about those things. The other 50% is made up of tech support, like you say and innovation (probably making up a small portion of that ~5%).
Re: Forum reorganization March 19, 2014 11:48PM |
Buback
Why, exactly, do we even need to host forums for lots of different electronics? or softwares? Shouldn't they have their own communities and forums? why not just pick one, and then support that one here and refine it until it's perfect, and switch when something better comes along (determined through votes, i guess, or by fiat, if someone is ballsy enough)
Re: Forum reorganization March 19, 2014 11:54PM |
Re: Forum reorganization March 20, 2014 12:18PM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Forum reorganization March 20, 2014 01:23PM |
Sublime
I do not think the idea of an official RepRap is good at all since there can not be an official without an owner. As it is any "Rep"licating "Rap"id prototyping machine is a RepRap. RepRap is about evolution and as with biological life there will be a lot of variations and species, all of which are descendents of the first even if they can not interbreed any longer. Trying to restrict that goes against the basis of a machine that evolves.
Re: Forum reorganization March 20, 2014 01:48PM |
Buback
Sublime
Where does the reprap project fit into that metaphor? Was it only just the seed? What it it's purpose now?
Re: Forum reorganization March 20, 2014 02:34PM |
Sublime
RepRap itself is nothing more than an idea and a place for people to work together.
Re: Forum reorganization March 20, 2014 02:58PM |
Buback
Sublime
that sentiment exactly why nobody bothers with the wiki.
Buback
If you want to stick with the evolutionary metaphor, consider this; there needs to be some type of forcing mechanism in order to promote one mutation over another. Otherwise, you just get random, unproductive mutations. I would like to see the reprap project as enforcing specific forcing mechanisms, such as reproducible part count, and cost, and ease of use. Designating a machine that meets those criteria best would, in my opinion, spur other developers to beat that machine. I don't think that hinders development at all.
Re: Forum reorganization March 20, 2014 03:40PM |
Why not encourage instead of enforce? If you have a vision you think people will rally behind, create a project page on the wiki, set up a bounty, get people to put money on it, and then don't shut up about it until someone does the work.Quote
Buback
Maybe for full disclosure you should also mention that the cover page of the wiki has a link to this page RepRap Options, and one of the machines on that page is this one and one of the dedicated subforums on this website is this one. It doesn't seem like you are being deprived of publicity...Quote
Sublime
Right now the cover page of the wiki has a link to this page [reprap.org] which can only be edited by a few privileged persons who are basically using it as an AD for their machines.
spacexula
I got enough nasty emails and conversations questioning my character that I am really not intersted in continuing the update of the front page any further. If someone else wants to take up the project have at it. I am done.
A lot of people on IRC think that IRC is the official seat of RepRap. I suggested we put the IRC button up at the top of the forums in an attempt to foster more interaction between the two (largely separate) groups. (The wiki has had a link to IRC in the sidebar since forever.)Quote
Sublime
If IRC is not an official place I think it should be removed from the Forum heading, if it s an official place it should not have AD's in its header.
I agree completely. But I think that if reprap ignores the trends of more conventional low-cost 3d printing, it will lose even more relevance. The commercial side of things is not going to go away, and I think people who care about the future of RepRap should acknowledge that. But I also think we can strike a balance between the mundane commercial work going on and cutting edge research into new fabrication methods, self-replication, and so on. We gotta be realistic.Quote
Sublime
If you look at the current designs they are actually going away from that. Most of them use fancy lead screws and extruded aluminum and special v-slides etc. The only machines that have been designed lately that I would consider closer to the original goal would be the work of Nicolas Seward but those are not the ones being promoted by the homepage of RepRap or IRC which promote those that use less replicating parts then their predecessor. The entire project is going backwards if we keep promoting the designs that are the fastest to manufacture. It should not matter if it takes a day or a year to self replicate if it means you do not need to rely on a corporation to manufacture part of your machine that is not necessary (like lead screws can be replaced with levers or strings or fluid)(Or frames that can be printed).
Re: Forum reorganization March 20, 2014 04:00PM |
Sublime
Re: Forum reorganization March 20, 2014 04:17PM |
You've probably heard about these projects already, but just in case: OpenSLS, Pwdr Model 0.1, Dragonator 3DP printerQuote
Buback
I'd actually love to see a powder reprap
Re: Forum reorganization March 20, 2014 04:40PM |
Re: Forum reorganization March 20, 2014 04:49PM |
MattMoses
Sublime
MattMoses
I don't know how many people remember the last time there was discussion about updating the official machines page, but it didn't go well. Here is what the hard-working volunteer had to say about it after trying to come up with a reasonable solution:
spacexula
MattMoses
Sublime
MattMoses
Sublime
Re: Forum reorganization March 20, 2014 05:48PM |
Admin Registered: 13 years ago Posts: 1,466 |
Sublime
I just talked about this in the thread in the general section but I will say it here again. IRC only holds people responsible for misinformation for the time it takes for the conversation to be pushed off the page which means bad advice gets proliferated or sends people off on wild goose chases without anyone being able to come along a day later to add to the conversation or correct it.
As for the side bar, is this another thing only editable by certain people? Maybe those that use IRC to influence people into their way without worry of actually having to defend what they say because the conversation is not preserved like on the forum?
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing. Anyone can edit the wiki! |
Re: Forum reorganization March 21, 2014 12:46AM |
This sounds OK to me. I like the RepRap Options page (even though it is disorganized) and it does not have any editing restrictions. The Build A RepRap page (the one with editing restrictions) seems to be really out of date anyway... A simple thing to do would be to change the link(s) on the main page so they all point to RepRap Options... We would probably need Adrian's OK, however.Quote
Sublime
I actually feel there should be no pages that have limited access and make decisions for people. That is the page I linked to should not exist and the home page should not have any machine specific information on it.
I didn't know you closed your store. Will keep this in mind in the future... Just a general comment, Sublime: if you want Admin privileges, just ask (probably Traumflug or VDX). Unless there is bad blood I don't know about, I don't think anyone would object to you being an admin. (For example I got involved just by volunteering to help clean up spam.)Quote
Sublime
I did add Tantillus to myself but it was after I closed my store and none of this was about promoting sales
The wiki sidebar is here. It does not appear to be locked (to me anyway).Quote
NewPerfection
I don't know how the sidebar is edited... Maybe one of the other admins knows.
Re: Forum reorganization March 21, 2014 01:43AM |
MattMoses
Sublime
MattMoses
Sublime
Re: Forum reorganization March 21, 2014 10:36PM |
Admin Registered: 10 years ago Posts: 1,063 |
Re: Forum reorganization March 21, 2014 10:49PM |
Re: Forum reorganization March 21, 2014 10:54PM |
Buback
I know there's no 'reprap administration' but i like this idea that we remove any printers that don't contribute monetary funds back to reprap.org. maybe with more funds reprap could hire a web developer...
Re: Forum reorganization March 21, 2014 11:43PM |
You will not find a bigger fanboy for self-replicating machines than myselfQuote
thejollygrimreaper
this is supposed to be about self replicating machines , in what world are printers like the eventorbot self replicating? why are they on this page at all? then there are the ones which use tslot as their primary structure ...
Re: Forum reorganization March 22, 2014 12:07AM |
MattMoses
thejollygrimreaper
this is supposed to be about self replicating machines , in what world are printers like the eventorbot self replicating? why are they on this page at all? then there are the ones which use tslot as their primary structure ...but even I acknowledge that if we kick out every piece of work that doesn't deal directly with self-replicating machines, we are not going to be left with much.
A big part of RepRap is also promoting open source hardware in low cost 3D printers. RepRap started this whole thing, and RepRap has a good chance of remaining the "go to" place for open source advanced manufacturing, unless we do something stupid and scare away everyone doing research on the topic.
Personally, I think the eventorbot is "moving away from self-replicating" compared to earlier designs, but ya know what? They've got a nice page on the wiki, the design files are easily available, the printer can print some of its own parts... I think it totally deserves a spot on the RepRap options page. (side note: the fact the handful of people participating in this thread can't agree on what should be on that page does not bode well for any type of reorganization process...)
When I see 32 machines on the RepRap options page I think "Wow, all of these printers came out of the RepRap project. All of these designs are part of the RepRap project. I want to design a printer that goes on this list. What is my printer going to look like?" So I don't see it as a bad thing...
Regarding the commercial links, I find it annoying when people edit the wiki only to put a link to their offsite shop. Some people have dozens of edits and every single one of them is just adding a one-line link to their crappy blog. I am fine if we try to reduce that behavior. But I think it is a bad bad idea to be too restrictive about what kind of links we allow. It will give reprap.org a bad reputation as a place that is unfriendly to small businesses. (I think that's bad and I'm not even selling anything!)
My recommendation is to always err on the side of less rules instead of more rules, and to deal with bad behavior (spam, blatant advertising, etc) on a case by case basis.
Re: Forum reorganization March 22, 2014 12:12AM |
How about this: if there is a link to a product that is known to be defective, add a warning and/or a link to a review, forum discussion, or some other source. Fight the problem with additional information.Quote
thejollygrimreaper
but i'm more concerned about the webshops for example that do things like stock the clone jheads which are made so badily they don't even have the right number of slots in them, and have given people all sorts of jamming trouble because they haven't seen a day of testing
Re: Forum reorganization March 22, 2014 06:55AM |
MattMoses
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Forum reorganization March 22, 2014 07:16AM |
Traumflug
MattMoses
How would you know a product to be "defective"? You have no sample yourself and the vendor will deny this immediately.
Re: Forum reorganization March 24, 2014 10:36AM |
thejollygrimreaper
most of the time the differences can be seen in the photos the seller uses
thejollygrimreaper
defective or not, in a lot of cases there are significant differences which should render the product a variant anyway and should stand on it's own two feet , not ride on another manufacturers reputation and deceive people who simply don't know any better, this is why i think the links in the wiki should either be removed or warnings attached next to them,
Re: Forum reorganization March 25, 2014 04:21AM |
