A2
How to attach a file to a PM.
April 13, 2014 02:18AM
How do I attach a .stl file to a PM.
Re: How to attach a file to a PM.
April 13, 2014 03:53AM
you actually can't do it,
what a lot of people seem to do is send a public drop-box link to the file, this obviously requires you to have dropbox installed,
-=( blog )=- -=( thingiverse )=- -=( 3Dindustries )=- -=( Aluhotend - mostly metal hotend)=--=( Facebook )=-
A2
April 13, 2014 04:01AM
OK, tks for the info.
Do you know why.
April 13, 2014 04:19AM
i think it's just a feature that isn't in phorum
April 13, 2014 11:53AM
Go to the "control center" in the forum and go to "my files" / "edit my files" and attach whatever you want (within the file size limit) and then right click on the newly uploaded file and copy its location and use that to attach the file in the PM.
This image is in my files.
Edited 1 time(s). Last edit at 04/13/2014 08:37PM by Sublime.
A2
April 13, 2014 05:54PM
Tks thumbs up
A2
April 15, 2014 01:30AM
Sublime
I have a .stl file, not a picture.
How would you attach a .stl file to a PM?
Tks.
April 15, 2014 02:12AM
Make sure it is saved as a binary STL not an ascii because the ascii makes very large files (you can use Meshlab or Blender to save it as a binary if your program will not). If it is still too large to attach you can compress it with something like a Zip or Tar.gz . If you need even more compression you can use tar.7z (use 7zip as the compression tool).
A2
April 15, 2014 02:57AM
Tks Sublime, thumbs up
