math expression doesn't work in the wiki
May 27, 2010 10:33AM
I wanted to have some formulas display nicely by using the MATH statement e.g.
MATH
\beta = \frac{\ln\left ( \frac{R}{R_{0}} \right )}{(\frac{1}{T + 273.15}) - (\frac{1}{T_{0} + 273.15})}
But this doesn't seem to work in the WIKI! eye rolling smiley
Edited 1 time(s). Last edit at 05/27/2010 10:47AM by rhmorrison.
Bob Morrison
Wörth am Rhein, Germany
"Luke, use the source!"
BLOG - PHOTOS - Thingiverse
open | download - CalculateBeta.png (1.1 KB)
Re: math expression doesn't work in the wiki
June 03, 2010 03:24AM
Suggestion: how about you just do what you've done in the forum, which is to take a picture of the formule, and upload that to the wiki page, and embwd the image. the end-users get the same result, which is that they can see you formula. :-)
June 03, 2010 06:00AM
I'll look at mediawiki math extensions.
-Sebastien, RepRap.org library gnome.
Remember, you're all RepRap developers (once you've joined the super-secret developer mailing list), and the wiki, RepRap.org, [reprap.org] is for everyone and everything! grinning smiley
June 03, 2010 01:06PM
Been there, done that! tongue sticking out smiley
Bob Morrison
June 03, 2010 11:59PM
If you just use the screenshot method it's not the same result, because end-users can't edit the formula.
June 04, 2010 11:45AM
No, that is why I wanted to use the math expression supported (or apparently not) by the wiki. If they get it working then I will change it back otherwise it is much more readable as a LaTex math forumala graphic then as a text formula.
Bob Morrison
June 18, 2010 12:14AM
I had this problem too, but figured I was just doing something wrong. Glad I'm not the only one... -Matt
June 18, 2010 03:35AM
I looked at this tonight, and turned on more options in the wiki, and compiled some TeX-related tools, but sadly it still has an issue I have not tracked down while trying to generate the image of the LaTeX formula. So now the wiki says:
Failed to parse (PNG conversion failed; check for correct installation of latex, dvips, gs, and convert): \beta = \frac{\ln\left ( \frac{R}{R_{0}} \right )}{(\frac{1}{T + 273.15}) - (\frac{1}{T_{0} + 273.15})}
Which means it is now at least trying to do the right thing with the LaTeX smiling smiley
Jonathan
June 18, 2010 03:39AM
smiling bouncing smiley Oh boy, that means your getting close to getting it to work!
I used the on-line LaTeX equation generator to generate the images that are currently in the wiki.
Bob Morrison
June 18, 2010 10:40PM
Alright people, LaTeX math now works in our Mediawiki... have fun geeking out with it smiling smiley
Jonathan
June 18, 2010 11:59PM
Thank you jonathan, that will help with the gear stuff.
June 21, 2010 06:23AM
jmarsden
Thanks Jonathan! It works GREAT!! thumbs up smileys with beer
Edited 1 time(s). Last edit at 06/21/2010 06:24AM by rhmorrison.
Bob Morrison
