Wiki
July 18, 2016 08:55AM
I used to modify the wiki when I first got my printer and updated a lot of stuff AND my updates (all of them) remain. I spent a lot of time updating the sections so I decided to update something and it says my ip is blocked from updating the wiki. Why?
_______
I await Skynet and my last vision will be of a RepRap self replicating the robots that is destroying the human race.
Re: Wiki
July 18, 2016 09:10AM
wiki aint as free and open as it used to be
Edited 1 time(s). Last edit at 07/18/2016 09:14AM by jinx.
Re: Wiki
July 18, 2016 09:27AM
You might have fallen in the middle of our evergoing war against spammers.
What is your username in the wiki ? You were trying from the same IP block (internet connection) you are using here ?
Re: Wiki
July 18, 2016 11:30AM
DeuxVis
Yep, same login and ip.
edit: Now I know my ip changes and I don't just mean the last octet either as I have seen me listed as in MI, and NJ, and IL before thanks to Comcast.
Edited 1 time(s). Last edit at 07/18/2016 11:31AM by Dark Alchemist.
_______
Re: Wiki
July 18, 2016 01:54PM
I'm investigating, you are not intentionally blocked so I have to dig up which other ban you ended up collateral.
Sorry and please be patient, I'm not usually working much on the wiki so I have to learn how it works.
Re: Wiki
July 18, 2016 08:12PM
DeuxVis
No problem as I was just surprised about that.
_______
Re: Wiki
July 19, 2016 09:36AM
To help me find where that blocking comes from, could you please try again and cut and paste the exact message you get ?
Re: Wiki
July 19, 2016 10:19AM
DeuxVis
Some reason my password does not work there so...
Internal error
Your IP address is blocked from editing, and so is not allowed to use the password recovery function to prevent abuse.
Return to Main Page.
_______
Re: Wiki
July 27, 2016 08:43PM
Any word on this?
_______
Re: Wiki
July 28, 2016 04:08AM
Sorry, no results from my investigation yet.
I'll try and put some more time into this issue asap.
Re: Wiki
September 29, 2016 04:57AM
Sorry I haven't had a chance to work on that recently.
Are you still blocked on the wiki DA ?
I'll ask some other admins to put some time in here if you still cannot log in or edit wiki pages.
Re: Wiki
September 29, 2016 09:23AM
DeuxVis
I finally was able to log in but I had to reset my password first. I noticed Comcast has updated my ip again so it is possible I have moved to a non blocked ip but seriously with Dynamic ip schemes blocking of ips is a bad idea unless from known spam countries.
Thank you for your help.
_______
