There is an error in http://reprap.org/wiki/Prusa_i3_Rework_Firmware
August 23, 2017 06:20PM
A new user in the IRC channel noted that the area where DRV8825 drivers are mentioned in the mm-per-step area contains a grievous error. Where it should day "if using DRV8825s then double this value," it currently says "If using DRV8825s, half (halve would be the correct form, nit pick) this value."
This must be causing considerable confusion. I suggest whomever maintains the forum correct this error.
Thank you
Re: There is an error in http://reprap.org/wiki/Prusa_i3_Rework_Firmware
August 24, 2017 03:38AM
It is a WIKI. Get an account, do the change and document in the discussions why you changed it. WIKIs live and die with user participation.
[www.bonkers.de]
[merlin-hotend.de]
[www.hackerspace-ffm.de]
