Re: Auto bed leveling (kapazitiv) + E3D Hotend nachgerüstet (RepRapPro Mendel) 26. July 2017 10:10 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 324 |
Re: Auto bed leveling (kapazitiv) + E3D Hotend nachgerüstet (RepRapPro Mendel) 26. July 2017 12:52 |
Registrierungsdatum: 11 Jahre zuvor Beiträge: 3.969 |
Re: Auto bed leveling (kapazitiv) + E3D Hotend nachgerüstet (RepRapPro Mendel) 12. August 2017 07:02 |
#define ENDSTOPPULLUPS //alle an #define X_MIN_ENDSTOP_INVERTING true // set to true to invert the logic of the endstop. #define Y_MIN_ENDSTOP_INVERTING true // set to true to invert the logic of the endstop. #define Z_MIN_ENDSTOP_INVERTING true // set to true to invert the logic of the endstop. #define X_MAX_ENDSTOP_INVERTING true // set to true to invert the logic of the endstop. #define Y_MAX_ENDSTOP_INVERTING true // set to true to invert the logic of the endstop. #define Z_MAX_ENDSTOP_INVERTING true // set to true to invert the logic of the endstop. #define Z_MIN_PROBE_ENDSTOP_INVERTING true // set to true to invert the logic of the probe. #define Z_MIN_PROBE_ENDSTOP // Mein Sensor ist direkt an den Anschluss z_min angeschlossen. #define FIX_MOUNTED_PROBE #define X_PROBE_OFFSET_FROM_EXTRUDER -25 // X offset: -left +right [of the nozzle] #define Y_PROBE_OFFSET_FROM_EXTRUDER -25 // Y offset: -front +behind [the nozzle] #define Z_PROBE_OFFSET_FROM_EXTRUDER +3 // Z offset: -below +above [the nozzle] Mein Sensor ist etwa 3 mm über der nozzlespitze #define AUTO_BED_LEVELING_3POINT #define ABL_PROBE_PT_1_X 50 #define ABL_PROBE_PT_1_Y 160 #define ABL_PROBE_PT_2_X 50 #define ABL_PROBE_PT_2_Y 50 #define ABL_PROBE_PT_3_X 190 #define ABL_PROBE_PT_3_Y 50 #define XY_PROBE_SPEED 8000 #define Z_PROBE_SPEED_FAST HOMING_FEEDRATE_Z #define Z_PROBE_SPEED_SLOW (Z_PROBE_SPEED_FAST / 2) #define Z_CLEARANCE_DEPLOY_PROBE 15 // Z Clearance for Deploy/Stow #define Z_CLEARANCE_BETWEEN_PROBES 5 // Z Clearance between probe points // For M851 give a range for adjusting the Z probe offset #define Z_PROBE_OFFSET_RANGE_MIN -20 #define Z_PROBE_OFFSET_RANGE_MAX 20 #define X_ENABLE_ON 0 #define Y_ENABLE_ON 0 #define Z_ENABLE_ON 0 #define E_ENABLE_ON 0 // For all extruders #define DISABLE_X false #define DISABLE_Y false #define DISABLE_Z false #define DISABLE_E false // For all extruders #define DISABLE_INACTIVE_EXTRUDER true // Keep only the active extruder enabled. #define INVERT_X_DIR true #define INVERT_Y_DIR false #define INVERT_Z_DIR true #define INVERT_E0_DIR false #define INVERT_E1_DIR false #define INVERT_E2_DIR false #define INVERT_E3_DIR false #define INVERT_E4_DIR false
Re: Auto bed leveling (kapazitiv) + E3D Hotend nachgerüstet (RepRapPro Mendel) 12. August 2017 07:18 |
Re: Auto bed leveling (kapazitiv) + E3D Hotend nachgerüstet (RepRapPro Mendel) 12. August 2017 07:36 |
Re: Auto bed leveling (kapazitiv) + E3D Hotend nachgerüstet (RepRapPro Mendel) 12. August 2017 07:43 |
Re: Auto bed leveling (kapazitiv) + E3D Hotend nachgerüstet (RepRapPro Mendel) 12. August 2017 09:18 |
Re: Auto bed leveling (kapazitiv) + E3D Hotend nachgerüstet (RepRapPro Mendel) 12. August 2017 09:21 |
Re: Auto bed leveling (kapazitiv) + E3D Hotend nachgerüstet (RepRapPro Mendel) 12. August 2017 09:27 |
Re: Auto bed leveling (kapazitiv) + E3D Hotend nachgerüstet (RepRapPro Mendel) 12. August 2017 09:29 |
Re: Auto bed leveling (kapazitiv) + E3D Hotend nachgerüstet (RepRapPro Mendel) 12. August 2017 09:40 |
Re: Auto bed leveling (kapazitiv) + E3D Hotend nachgerüstet (RepRapPro Mendel) 12. August 2017 11:15 |
Dfix1
In der Firmware sollte #define Z_SAFE_HOMING eingetragen sein. Dann funktioniert das wie Fridi schon vermutet hat. Er homed x und y, fährt dann zur Druckbettmitte und nimmt mit dem Sensor Z
Es ist also keine Anpassung der Homeposition nötig.
Re: Auto bed leveling (kapazitiv) + E3D Hotend nachgerüstet (RepRapPro Mendel) 12. August 2017 11:42 |
Re: Auto bed leveling (kapazitiv) + E3D Hotend nachgerüstet (RepRapPro Mendel) 12. August 2017 13:36 |
Re: Auto bed leveling (kapazitiv) + E3D Hotend nachgerüstet (RepRapPro Mendel) 23. September 2017 17:37 |
Registrierungsdatum: 6 Jahre zuvor Beiträge: 9 |
Re: Auto bed leveling (kapazitiv) + E3D Hotend nachgerüstet (RepRapPro Mendel) 12. November 2017 17:49 |
Registrierungsdatum: 8 Jahre zuvor Beiträge: 155 |
Re: Auto bed leveling (kapazitiv) + E3D Hotend nachgerüstet (RepRapPro Mendel) 06. January 2018 10:06 |
Registrierungsdatum: 6 Jahre zuvor Beiträge: 2 |
Re: Auto bed leveling (kapazitiv) + E3D Hotend nachgerüstet (RepRapPro Mendel) 21. March 2018 13:22 |
Registrierungsdatum: 6 Jahre zuvor Beiträge: 1 |
