Hallo vielleicht kann mir jemand weiter helfen was dieser fehler ist von der Marlin MMU2 Firmware
Arduino: 1.8.13 (Windows 10), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
In file included from D:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:30:0,
from c:\users\patri\appdata\local\temp\arduino_build_7181\sketch\src\hal\shared\marduino.h:35,
from c:\users\patri\appdata\local\temp\arduino_build_7181\sketch\src\hal\hal_avr\hal.h:21,
from c:\users\patri\appdata\local\temp\arduino_build_7181\sketch\src\hal\hal.h:26,
from c:\users\patri\appdata\local\temp\arduino_build_7181\sketch\src\inc\marlinconfig.h:30,
from sketch\src\HAL\HAL_AVR\MarlinSerial.cpp:39:
sketch\src\HAL\HAL_AVR\MarlinSerial.cpp: In function 'void __vector_51()':
sketch\src\HAL\HAL_AVR\MarlinSerial.cpp:744:22: error: redefinition of 'void __vector_51()'
ISR(SERIAL_REGNAME(USART,INTERNAL_SERIAL_PORT,_RX_vect)) {
c:\users\patri\appdata\local\temp\arduino_build_7181\sketch\src\hal\hal_avr\MarlinSerial.h:51:54: note: in expansion of macro 'SERIAL_REGNAME_INTERNAL'
#define SERIAL_REGNAME(registerbase,number,suffix) SERIAL_REGNAME_INTERNAL(registerbase,number,suffix)
sketch\src\HAL\HAL_AVR\MarlinSerial.cpp:744:7: note: in expansion of macro 'SERIAL_REGNAME'
sketch\src\HAL\HAL_AVR\MarlinSerial.cpp:724:24: note: 'void __vector_51()' previously defined here
ISR(SERIAL_REGNAME(USART,SERIAL_PORT_2,_RX_vect)) {
sketch\src\HAL\HAL_AVR\MarlinSerial.cpp:724:9: note: in expansion of macro 'SERIAL_REGNAME'
sketch\src\HAL\HAL_AVR\MarlinSerial.cpp: In function 'void __vector_52()':
sketch\src\HAL\HAL_AVR\MarlinSerial.cpp:748:22: error: redefinition of 'void __vector_52()'
ISR(SERIAL_REGNAME(USART,INTERNAL_SERIAL_PORT,_UDRE_vect)) {
sketch\src\HAL\HAL_AVR\MarlinSerial.cpp:748:7: note: in expansion of macro 'SERIAL_REGNAME'
sketch\src\HAL\HAL_AVR\MarlinSerial.cpp:728:24: note: 'void __vector_52()' previously defined here
ISR(SERIAL_REGNAME(USART,SERIAL_PORT_2,_UDRE_vect)) {
sketch\src\HAL\HAL_AVR\MarlinSerial.cpp:728:9: note: in expansion of macro 'SERIAL_REGNAME'
exit status 1
Fehler beim Kompilieren für das Board Arduino Mega or Mega 2560.
