[www.kickstarter.com]
I'm the project-owner for this Kickstarter campaign.
I made a sensor that can detect pretty much any kind of filament stoppage. If your printer can take an endstop filament runout sensor, then it can use this product as a drop-in replacement.
I've tested this product on a Ramps 1.4 with Marlin 1.1.x. I've also tested it on OctoPrint with the filament sensor plugin.
I haven't directly tested it, but it should also work well with Repetier firmware (quadrature output).
This isn't a take-it-or-leave-it campaign; if you see a function you'd like but don't see, then request it and I'll try my best to incorporate it.
If you have any questions, submit and I'll answer as fast as I can!
Thanks!
Based on the pictures, it appears to be massive in size and really only suitable for your reel stand or a bowden type setup. It doesn't appear as it would be easy to mount on say an E3D Titan extruder unless you had it in the bowden configuration. And your board/kit looks like it relies on a reel be supported by the flange which is not really the best method of holding a payoff.
Realistically, I'd have to suggest you find a way to design something smaller in size that could hang on a small PTFE tube above a direct drive extruder, or something that is light weight and wouldn't add a huge mass or object on a X carriage.
Good luck with it either way, what you have might work but really doesn't seem practical.
