X axis - Correct direction
Posted by eiaro
December 23, 2013 03:54AM
I'm wondering if my X axis is working correctly. When moving out on the X axis from the Z axis profile toward the end of X axis, X counts down. I do run CNC machines on a regular basis, and this seems wrong.
This also causes problems homing the X. I can park the X just over the notch, and it homes directly. Moving out a bit and pressing home again, the carrige moves to the outer end of the axis and stalls the stepper.
Z axis seems to be working, so the sensor should be OK.
Re: X axis - Correct direction
December 23, 2013 03:57AM
Hi eiaro,
did you check the wiring? The x-motor-connector is the only one which is reversed in the connection compared to the other motors.
Markus
XBee & electronics blog: [lookmanowire.blogspot.com]
December 23, 2013 07:27AM
I just wired it like the others, so thats probably the solution. I will test tonight and confirm. grinning smiley
UPDATE:
Turning the connector solved that problem smiling smiley
Edited 1 time(s). Last edit at 12/23/2013 01:50PM by eiaro.
