Hi Mike
I'm not going to get drawn into an argument about cost, but please understand that we have put a lot of effort into producing this kit. It's not just the cost of the components, but the dedicated team behind it, the open source community that has contributed to the development, the staff that hand-produce a low-volume product, and the after-sales support we offer.
Without trying to sound too defensive, I'd like to address your points, to help you with your build:
- the "laser cut" parts have a warp on them
Not quite sure why you are putting "laser cut" in quotes? They ARE laser cut. If you have any fit problems, email me and request a new pair of x-rib and x-axis-plate. We have updated the lasercut parts for better fit, though a few minutes with a file will make them slot easily together, if you have problems. They shouldn't be under stress; they will bend, and probably break.
- The x carriage won't run along it happily at all
In what way? Do you mean the bearing on the back of the x-axis-plate? The weight of the hot end holds the bearing at the back against the plate. Some people have found the 9mm bearing gets trapped by the washer when done up; if you turn the washer over, because the washers are dished where they are stamped out, it should free the bearing. Some people have also found fitting a 623 bearing helps.
- y axis belt won't stay locked in place no matter how many bits of paper I wedge in place , needs a tensioner on it and a more positive way of fastening the belt
Are you sure you're pushing it to the back of the slot? This is one part that we have still to look at for updating, but few people have reported a problem. Another option it to clamp one of the foldback clips, or a cable tie, up against the rib, with the tail of the belt in the upper slot.
- The roller bearings that run on the Bosch extrusion need adjusters ,not sticky tape
some z-bearing-mounts seem to have printed 0.25mm wider than others. We have updated this with an adjustable part. Some people find it a problem, some don't. The part is available to print yourself - the printer will print happily with the fix shown in the instructions. I can send you a new adjustable one, but it will be green.
- The Bosch section could be tied together more positively ,then perhaps one alignment issue would be lessend
This would take an extra machining operation, and is unnecessary with the bracing already there. It doesn't have to be as robust as a drill/mill - the extruder doesn't have to push itself through material. As it is, it is far more robust than other framing methods used in the reprap world.
- And they might of specced hardened ground rod for the linear bearing rails
It IS hardened ground rod - CK55 - [
www.metalravne.com]
Please take this as advice to help your printer build. I'm here to help, and we're committed to getting every customer printing.
Ian
RepRapPro tech support
