PSU Cutting out... January 07, 2014 03:30PM |
Re: PSU Cutting out... January 07, 2014 03:43PM |
Re: PSU Cutting out... January 07, 2014 03:45PM |
TMD_RS436
So it sounds like I may have an iffy PSU or the printer is taking too much current from the PSU.
I have also noticed that when the heaters are on the little fan slows down a little, I don't know if anyone else gets this as well.
TMD_RS436
PS the 10mm bearing change didn't help much, the whole hot end still sags and needs to be tilted by another 0.8mm
Re: PSU Cutting out... January 07, 2014 03:48PM |
Re: PSU Cutting out... January 07, 2014 03:58PM |
tim_h
Bad luck Paul, I had the same problem, see this post http://forums.reprap.org/read.php?340,287773
I solved mine with second hand PSU from a scrapped PC. I don't think the Alpine PSUs are the best quality...
Tim
Re: PSU Cutting out... January 07, 2014 04:09PM |
dc42
TMD_RS436
Sounds to me that you need to ask RRP for a replacement PSU. But the fan slowdown when the bed heater comes on is normal, the 12V supply on cheap ATX PSUs isn't well regulated (nor does it needs to be in this application).
dc42
TMD_RS436
Yes, my unit really needs an 11mm bearing too, both with the x-carriage part I received with the kit and with my own replacement printed part. In both cases, to solve it I had to elongate the slot and the nut trap as well as fit a 10mm bearing. I think RRP needs to adjust the design of that part.
Re: PSU Cutting out... January 07, 2014 04:10PM |
TMD_RS436
Well the PSU supplied to me was made by Ace and says the +12V line can handle up to 24A Max.
Re: PSU Cutting out... January 07, 2014 04:25PM |
Treth
Not sure about the PSU, it could be a fault or a short. But you could try increasing the load on the PSU 5V and 3.3V supplies as the built in resistors are just below the minimum load spec and just could be the issue as the PSU could turn off it these are sensed as being too low a load current.
Treth
for the hot end sag, make sure the slot where the bearing screws into the nut is clear and you can slide the nut fully in for adjustment.
Treth
Also check the bolts that hold the hot assembly to the sliding part are in a good position as this is a socket head bolt in a countersunk recess in the printed part. Washers may help. Have a good look round the assembly to see what is parallel with the arm to try and be sure of the specific area causing the problem. Post a photo if you would like us to examine.
Re: PSU Cutting out... January 07, 2014 04:39PM |
dc42
TMD_RS436
Interesting, the Alpine one says 32A max. But 24A should be more than enough,
dc42
I'm wondering whether the sudden reduction in load when the bed heater turns off causes the output of these PSUs to momentarily rise to a point at which an overvoltage circuit cuts in and shuts the supply down. If that's the case, then adding a few thousand uF on the 12v line at the ATX board or the Duet input might help.
Re: PSU Cutting out... January 07, 2014 05:17PM |
TMD_RS436
Well I didn't know the power requirements of printer so I wouldn't know.
TMD_RS436
dc42
Yeah, but that wouldn't answer the issue where it cut out when I reconnected it after 5 seconds after last cut out and I only told it to home itself.
Re: PSU Cutting out... January 07, 2014 05:48PM |
Re: PSU Cutting out... January 07, 2014 07:58PM |
Re: PSU Cutting out... January 08, 2014 02:22AM |
Re: PSU Cutting out... January 08, 2014 02:45AM |
Re: PSU Cutting out... January 08, 2014 04:30AM |
Re: PSU Cutting out... January 08, 2014 06:58AM |
Re: PSU Cutting out... January 08, 2014 07:06AM |
Re: PSU Cutting out... January 08, 2014 11:17AM |
