Releasing a print January 20, 2014 03:32PM |
Re: Releasing a print January 20, 2014 05:04PM |
Re: Releasing a print January 20, 2014 05:52PM |
Re: Releasing a print January 20, 2014 08:04PM |
KimBrown
Hi John, I've been turning the bed off, leaving for a couple of minutes then just tap them with my fingers.
What settings are you using for Slic3r by the way?
Tried nearly all the ones that are suggested, but if doesn't seem to work.
Try as I do, I can't seem to get it to work. I get some of the first layer, then nothing.
The printers working fine with the coat hot...(if I make any more I'll open a coat hook shop).
Works fine with the calibration test pieces.... But when I try to print something I've sliced,
no joy.....
Kim
Re: Releasing a print January 20, 2014 08:24PM |
Install our profiles: [www.reprappro.com]Quote
arnaud31
click the box Use relative E distances in Printer settings generalQuote
KimBrown
What settings are you using for Slic3r by the way? Kim
Re: Releasing a print January 20, 2014 08:35PM |
droftarts
arnaud31
KimBrown
Ian
RepRapPro tech support
Re: Releasing a print January 21, 2014 03:40AM |
Re: Releasing a print January 21, 2014 04:11AM |
Re: Releasing a print January 21, 2014 05:02AM |
Re: Releasing a print January 21, 2014 02:38PM |
Re: Releasing a print January 21, 2014 02:59PM |
Re: Releasing a print January 21, 2014 04:37PM |
Re: Releasing a print January 22, 2014 02:52PM |
johneato
Just received my first reel of ABS so I'll give it a go. Picking up the new pieces of glass tomorrow so if the glass does break I'll have a spare
Re: Releasing a print January 22, 2014 03:22PM |
Re: Releasing a print January 22, 2014 03:46PM |
Re: Releasing a print January 22, 2014 07:35PM |
Re: Releasing a print January 23, 2014 03:17AM |
dmould
The H&S inspector even measures the temperature of the water from our hot taps to make sure it is barely warm.
Re: Releasing a print January 23, 2014 10:01AM |
dc42
dmould
I remember my H&S inspections when I ran a company with 20 employees. On the first one, the inspector found a trailing cable (trip hazard) which he told us to get rid of, but said everything else was OK. For the second, we made sure there were no trailing cables or any other obvious hazards. The H&S inspector started picking up on stupid things, e.g. "You've got bleach in the cleaning cupboard - someone might drink that!". So after that, we always put out a trailing cable when an H&S inspector was due, so that he would find it, tell us off, and be happy that he had done his job.
