Guys,
I have finished building the printer and now I am in the commisiong phase. I have installed Pronterface and the latest firmware.
- Motors can be controlled using Pronterface. So I guess communication/power is working fine
- Both Temperatures are at -273 (not connected properly?)
- Hot end Fan not working when connected to the Duet as indicated. If I move the connector for the Hot end Fan to the next row of pins it works (but I can not switch it on/off on Pronterface). So the intended Pins for the Hot end fan simply don't have power/voltage.
Any suggestions?
