Hot end Issues
Posted by trilby
Hot end Issues
February 08, 2014 10:53AM
Hello
I have just started having issues with my hot end thermistor not giving a reading (-274) after a week of printing. Can some one please tell me the expected values from it at room temperature.
This should hopefully help me diagnose if it is a wiring or thermisor fault (and pray that its not the duet thats dead).
Thanks
Re: Hot end Issues
February 08, 2014 11:03AM
The thermistor should be 100K @ 25C. I had this kind of problem too, it turned out to be a problem with the 6-pin connector.
Re: Hot end Issues
February 08, 2014 11:08AM
Or maybe one of the crimps have come off the thermistor.
Paul
RS Ormerod No 436
Re: Hot end Issues
February 08, 2014 11:12AM
I have done a visual check of the wires and checked the connector block so now it is on to checking continuity.
Well after i have taken a break for a while.
Re: Hot end Issues
February 08, 2014 05:33PM
mine did just that (after 1 week off printing), at first I checked the connections then checked the thermistor and took the wiring apart, but could not find any problems. put it back together and then I worked again.
either TMDRS336 is right or it was pure luck on my side, properly both.
been printing ever since....
