There are several other things you can do as well, which you will find by reading through this forum. The main problem is that your X carriage is drooping (the fan is not vertical), and that can be adjusted by changing the bearing on the X carriage (at the back of the acrylic plate) to a slightly bigger one to twist the whole carriage more vertical, or put a spacer between the plate and bearing (a hacksaw blade works well). When you have the machine working, there is a modified X carriage to print that allows a bigger adjustment of the bearing.
Dave
(#106)
