Levitated a bit before print
Posted by antlvk
March 23, 2014 09:37AM
Sometimes printes well sometimes it levitate a bit while printing so the extrusion not sticking to the bed.
**Start code** then
G1 F1800 e-1.0
g1 z0.2 f9000
g1 x60.687 f9000
g1 e1 f1800
then the printing stuffs code.....
g1 z0.2 f9000 what this code for? does it raise my Z? where is that code generated from?
Edited 1 time(s). Last edit at 03/23/2014 09:41AM by antlvk.
Re: Levitated a bit before print
March 23, 2014 12:52PM
antlvk
Yes. You presumably specified a 0.2mm layer thickness, so this is to raise the nozzle 0.2mm off the bed before starting the first layer.
March 23, 2014 09:31PM
So that should be normal?
another problem are in my g-codes
m140 S65;
i've set everywhere the bed temperature to 110 but when do slicing again the gcodes come out 65? any idea?
Edited 1 time(s). Last edit at 03/23/2014 09:52PM by antlvk.
March 23, 2014 10:16PM
found it in start code, nvm winking smiley
