z probe problem
Posted by PaulHam
z probe problem
April 29, 2014 07:15AM
I have the standard z probe and its been working ok for me recently, but today i have changed my z gears to iamburnys gears turned on the printer and the Z probe is indicating from 1015 - 1020
This means i cannot home the X axis.
I have checked the plug on the probe circuit and it is pluged in, and i have checked the wire going into the top row of the duet and that is pluged in too.
any ideas?
EDIT - as i was writing this i thought i should check the 2 other wires from the z probe circuit, and yes, they had come unpluged!
all sorted
Edited 1 time(s). Last edit at 04/29/2014 07:18AM by PaulHam.
Re: z probe problem
April 29, 2014 11:41AM
I was always knocking the 3 pin connector off the sensor board, so I hard wired it in the end. I made up a small PCB with connectors on that sits on top of the fan enclosure.
Regards,
Les
Pointy's Things
Pointy's Blog
Re: z probe problem
April 29, 2014 12:40PM
My replacement sensor board uses a connector with a locking tab to stop it falling off:
The 4-pin one is for the sensor loom, the 8-pin one os for the hot end loom.
