Thinking of trying a water cooled hot end April 21, 2014 06:57AM |
Re: Thinking of trying a water cooled hot end April 21, 2014 07:03AM |
Re: Thinking of trying a water cooled hot end April 21, 2014 07:23AM |
Re: Thinking of trying a water cooled hot end April 21, 2014 07:46AM |
Re: Thinking of trying a water cooled hot end April 21, 2014 08:06AM |
Re: Thinking of trying a water cooled hot end April 21, 2014 08:29AM |
Re: Thinking of trying a water cooled hot end April 21, 2014 09:21AM |
Re: Thinking of trying a water cooled hot end April 22, 2014 09:25AM |
Re: Thinking of trying a water cooled hot end April 22, 2014 09:41AM |
Re: Thinking of trying a water cooled hot end April 22, 2014 09:52AM |
Re: Thinking of trying a water cooled hot end April 22, 2014 01:33PM |
Re: Thinking of trying a water cooled hot end April 23, 2014 07:51AM |
Re: Thinking of trying a water cooled hot end April 23, 2014 12:57PM |
Re: Thinking of trying a water cooled hot end April 23, 2014 01:39PM |
Re: Thinking of trying a water cooled hot end April 23, 2014 02:24PM |
Re: Thinking of trying a water cooled hot end April 23, 2014 02:30PM |
Re: Thinking of trying a water cooled hot end April 23, 2014 02:37PM |
jstck
Since you wouldn't really need the heatsink and cooling fan for the hotend, you could have a "cooling block" that is a fair bit larger than just the standard block.
Re: Thinking of trying a water cooled hot end April 23, 2014 03:22PM |
jstck
Well, one thing would be to make the printer quieter (as the hotend cooling fan is by far the most noisy thing on the printer). Also because it's cool and challenging. But, if someone is making one, might as well do one with room for 3 or so nozzles.
Re: Thinking of trying a water cooled hot end April 23, 2014 03:32PM |
Re: Thinking of trying a water cooled hot end April 23, 2014 04:40PM |
T3P3
Hi Guys
Its a water cooled monster
Tony
Re: Thinking of trying a water cooled hot end April 23, 2014 05:06PM |
Re: Thinking of trying a water cooled hot end April 24, 2014 05:12AM |
Re: Thinking of trying a water cooled hot end April 24, 2014 06:05AM |
JMC
As for why ? i like to be able to see what im printing without having to peer under the fan and cooling vents.
Re: Thinking of trying a water cooled hot end April 24, 2014 06:24AM |
dmould
JMC
Why not simply take a hacksaw to the cooling vents as I have done? Then block the air channel to the vents and drill a hole in the top of the fan block for the air to get out instead. Sure, there is still the fan block present, but you have plenty of clearance to print up close to the clips etc., and I get a very reasonable view of the print. If I wanted a slightly better view it would be trivial to design a different fan block so that nothing extends below the bottom of the cooling block. (Which I intend to do as soon as I can source a round tooit, as well as making a separate controllable fan for cooling bridges),
Dave
(#106)
Re: Thinking of trying a water cooled hot end April 24, 2014 07:16AM |
JMC
dmould
JMC
Dave
(#106)
:-) done that but want to go further.
Re: Thinking of trying a water cooled hot end April 24, 2014 07:27AM |
dmould
As an idle musing, I wonder whether a Peltier cooler would pump sufficient heat away from the cool block? We have high current 12V DC readily available, and it would do away with complex plumbing.
Re: Thinking of trying a water cooled hot end May 10, 2014 10:07AM |
Re: Thinking of trying a water cooled hot end May 10, 2014 02:02PM |
Re: Thinking of trying a water cooled hot end May 11, 2014 08:50AM |
Re: Thinking of trying a water cooled hot end May 11, 2014 09:47AM |
