Big Blue 360 April 17, 2014 08:31PM |
Re: Big Blue 360 April 17, 2014 10:06PM |
Re: Big Blue 360 April 18, 2014 02:50AM |
Re: Big Blue 360 April 18, 2014 03:37AM |
Re: Big Blue 360 April 18, 2014 09:33AM |
Re: Big Blue 360 April 19, 2014 04:39AM |
Re: Big Blue 360 April 20, 2014 06:13PM |
Re: Big Blue 360 April 21, 2014 08:57PM |
Re: Big Blue 360 April 21, 2014 10:34PM |
Re: Big Blue 360 April 22, 2014 04:51AM |
Re: Big Blue 360 April 22, 2014 05:51AM |
KimBrown
Please give me feed back as to how you get on with fettling it, and anything else that might need addressing as the release your getting now I won't have time to print.
Re: Big Blue 360 April 22, 2014 06:00AM |
Re: Big Blue 360 April 22, 2014 06:24AM |
Re: Big Blue 360 April 22, 2014 06:51AM |
Re: Big Blue 360 April 22, 2014 06:56AM |
Re: Big Blue 360 April 22, 2014 07:34AM |
Re: Big Blue 360 April 22, 2014 07:47AM |
Re: Big Blue 360 April 22, 2014 08:19AM |
Re: Big Blue 360 April 22, 2014 09:13AM |
Re: Big Blue 360 April 22, 2014 09:14AM |
Re: Big Blue 360 April 23, 2014 05:42PM |
Re: Big Blue 360 April 23, 2014 07:02PM |
Re: Big Blue 360 April 24, 2014 02:05AM |
KimBrown
My next idea is to add a software adjustable flap to the exhaust port , so altering the amount of cooling automaticaly...
Re: Big Blue 360 April 24, 2014 04:39AM |
jstck
Why not use the existing firmware function to just control the speed of the fan? If you connect the fan to the actual fan header on the Duet (instead of just +12V as per the instructions), you can control the speed with M106.
Re: Big Blue 360 April 24, 2014 05:56AM |
Re: Big Blue 360 April 24, 2014 07:16AM |
Re: Big Blue 360 April 24, 2014 09:00AM |
KimBrown
As for the M106 fan speed, I'm not sure if it's just a case of swapping pins of the fan connection, as I don't know if the PWM pin can take the load of the fan. I'm sure DC could answer that question. I was going to design a servo controlled flap as the servo would react quicker than the fan speed changing.
Re: Big Blue 360 April 24, 2014 09:16AM |
Re: Big Blue 360 April 24, 2014 10:04AM |
KimBrown
Hi Dave, yes your right.... I'm not fully awake here after the long shifts...
My thoughts were to use a servo with the voltage dropped (I'd have to do similar to the PWM signal), to operate the flap.
Initialy I was going to link the servo to a cheap servo tester mounted in a box on top of the electronics box, as this would make altering the flap a breeze
during printing. Then DC suggested the M106 signal, so dropping the voltage might be best. It's easy enough to do.
I'll have a play around with it over the next few days.... I need to find the mocro servos I've put in a safe place first....lol
Re: Big Blue 360 April 24, 2014 11:50AM |
KimBrown
