ormerod surrounding temperature May 22, 2014 05:02AM |
Re: ormerod surrounding temperature May 22, 2014 08:01AM |
Re: ormerod surrounding temperature May 22, 2014 08:48AM |
Re: ormerod surrounding temperature May 22, 2014 09:45AM |
Re: ormerod surrounding temperature May 22, 2014 09:59AM |
88Zombies
all great advice!!! Thank you.
I was thinking of using one of these to regulate teh temperature;
[www.amazon.co.uk]
i was thinking of jsut hoooking that up to a fan at the top to help extract heat??
I think I'll attempt to print the ABS spre parts before any enclosure is added.... good advice..
Re: ormerod surrounding temperature May 22, 2014 11:02AM |
VortyZA
As Dave said, you shouldn't let the temperature get too high. As a brand new user that hadn't read ALL the instructions I tried to print ABS and battled. I read that the bed can get to higher temperatures in a box, so I put the printer in the box and set it going!
I'm pretty sure you see where this is heading - the final result was that I softened most of the PLA parts and bearings started slipping and rattling, the head started drooping and other exciting problems! (doh!)
Re: ormerod surrounding temperature May 22, 2014 11:45AM |
Re: ormerod surrounding temperature May 22, 2014 12:44PM |
