Gnaving away the threaded rodsad smiley
Posted by Aagaard
June 15, 2014 05:48PM
Hi Guys,
I'm just posting to know it anyone has experinced that the nut carrying the x-axis, has started to gnav away the threaded rod, and why? (see picture: [www.dropbox.com])
Where I supposed to grease up the nut? Have I done something wrong during assembly?
And does anyone have a idea for a fix?
Whenever move up the z-axis by 10 mm og more it becomes really obvious, sounds really bad, that its grinding those threads good. And it seems that the bolt has forced itself to some extra space, as it now is able to turn a couple of degrees freely.
Re: Gnaving away the threaded rodsad smiley
June 16, 2014 02:00AM
That's a very common problem.
I have had great experience with a stainless steel rod and a long brass-nut. Both things can be found on Ebay at very reasonable prices.
The long brass-nut can be hard to find. I have been using this one for a couple of moths without any problems: [cgi.ebay.co.uk]
Make sure to oil/grease your rod a little bit.
Best regards,
Carsten
June 16, 2014 04:55AM
Same here, I am using the standard threaded rod and the brass long nut from ebay, working great so far.
If the rod is worn, replace that as well as fitting the brass long nut or it will chew the new nut pretty quickly.
I use 3-in-1 oil on my rod.
Another RS Ormerod Mk1 meets the world smiling smiley
Retired now but I used to make....
CNC Machined Mk1 aluminium bed support plates for the Ormerod
CNC machined X-plates and ribs for Mk1 & Mk2 Ormerods
CNC machined bed support arms for the Mk2 Ormerod.
Dual Hot-End heatsink blocks.
