New USer slicing and printing June 30, 2014 03:16AM |
Re: New USer slicing and printing June 30, 2014 08:56AM |
Re: New USer slicing and printing June 30, 2014 09:24AM |
Re: New USer slicing and printing June 30, 2014 10:44AM |
jstck
..In the latest dc42 firmware/web-ui, there is a slider to control extrusion amount on the fly when printing. With that, you should be able to tune it and seeing "live" what happens. Just print something large and flat with a few solid infill layers, which will give you time to experiment.
miscsolutions.wordpress.com
4. Print not going well? Adjust print speed and extrusion factor on the fly!
You can adjust the print speed on the fly by sending M220 S### where ### is the percentage of the normal print speed you want. For example, M220 S50 will print at half speed. You can’t override the maximum speeds with M220, you’ll need to use M203 to do that.
Similarly, you can adjust the extrusion factor by sending M221 S### where ### is the percentage of the normal extrusion amount that you want.
Re: New USer slicing and printing June 30, 2014 03:28PM |
Re: New USer slicing and printing July 01, 2014 07:37AM |
dolflombard
Thanks for the replies.
I am really fedup with this thing!
It turns out the head is blocked, the filament is coming out in spurts.
I took it apart to see if I can find a problem and broke of the little copper pipe. Problem is I sit in South Africa, I bought the kit from RS Components here who only sells the kits but don't have spare parts.
Dolf
Re: New USer slicing and printing July 01, 2014 08:32AM |
Re: New USer slicing and printing July 01, 2014 09:12AM |
Re: New USer slicing and printing July 01, 2014 09:14AM |
Re: New USer slicing and printing July 01, 2014 10:10AM |
Re: New USer slicing and printing July 01, 2014 10:30AM |
Re: New USer slicing and printing July 02, 2014 02:39AM |
Re: New USer slicing and printing July 02, 2014 03:42AM |
Re: New USer slicing and printing July 02, 2014 04:39AM |
Lejoni
Hope you have better luck with another model.
Re: New USer slicing and printing July 02, 2014 11:23AM |
